Kingston 1GB Module
Kingston 1GB Module
Quicklinx: 2PMMWS00 Mfr#: D12864B250
Kingston is the world's largest independent memory manufacturer. In today's performance-driven environment, memory upgrades provide an easy, economical alternative to increase system performance. Every memory product Kingston offers is designed to help you get maximum performance at the best price to you.
This memory is designed for the following systems:
Acer AcerPower Sd Series, Aspire G500, G600, G600p, M500, M500p, Veriton 5500, 3300D, 3500, 3500G, 5200D, 5500G, 7200D, 7500, 7500G;
MPC/Micron Client Pro 325 Series, Millennia Max XP Series, Millennia Max XP+ Series;
Sony VAIO PCV-RX742;
WinBook PowerSpec 4982, 6238, 8335,8707, 8730, 8822.
Kingston - DDR - module - 1 GB - DIMM 184-PIN - 266 MHz / PC2100
Memory module
1 GB
Memory Type
DDR SDRAM - DIMM 184-PIN
Upgrade Type
System specific
Speed
266 MHz (PC2100)
Voltage
2.5 V
Limited lifetime warranty (Germany, Austria and France - 10 years)
Acer AcerPower Sd, SV; Aspire G500, G600, G600p, M500, T100, T300, T310; Veriton 3300D, 3500, 3500G, 5200D, 5500, 5500G, 7200D, 7500, 7500G; MPC ClientPro 125, 145, 325; Millennia XP+; Packard Bell iMedia 1401, 1402, 1501; iXtreme 6090; Sony VAIO PCV-RX742
1 GB
Upgrade Type
System specific
DRAM memory module
DDR SDRAM
DIMM 184-PIN
Speed
266 MHz (PC2100)
Voltage
2.5 V
Compatible Slots
1 x memory - DIMM 184-PIN
Acer AcerPower Sd, SV , Acer Aspire G500, G600, G600p, M500, T100, T300, T310 , Acer Veriton 3300D, 3500, 3500G, 5200D, 5500, 5500G, 7200D, 7500, 7500G , MPC ClientPro 125, 145, 325 , MPC Millennia XP+ , Packard Bell iMedia 1401, 1402, 1501 , Packard Bell iXtreme 6090 , Sony VAIO PCV-RX742
