All Kingston® memory modules must perform properly to ensure maximum performance. Therefore, Kingston has developed an industry leading quality process to ensure that Kingston memory delivers superior quality, performance, and 100% compatibility with the computing system the module is designed for. Kingston, the world's largest independent memory manufacturer, has over 2, 000 memory products. In today's performance-driven environment, memory upgrades provide an easy, economical alternative to increase system performance. Every memory product Kingston offers is designed to help you get maximum performance at the best price to you.
- Kingston - DDR3 - module - 1 GB - SO-DIMM 204-pin - 1066 MHz / PC3-8500 - unbuffered
- Product Type
- Memory module
- Capacity
- 1 GB
- Memory Type
- DDR3 SDRAM - SO-DIMM 204-pin
- Upgrade Type
- System specific
- Data Integrity Check
- Non-ECC
- Speed
- 1066 MHz (PC3-8500)
- Unbuffered
- Limited lifetime warranty (Germany, Austria and France - 10 years)
- Designed For
- Acer Aspire 1551, 1820, 1825, 3410, 3935, 4251, 4552, 4736, 5251, 5252, 5334, 5336, 5551, 5732, 5734, 5736, 5737, 5738, 5740, 5741, 5742, 5745, 5943, 7551, 7552, 7741, 7745, 8943; Extensa 5235, 5635; TravelMate 4740, 5740, 6293, 6293 3G, 6493, 6593
- Capacity
- 1 GB
- Upgrade Type
- System specific
- DRAM memory module
- Technology
- DDR3 SDRAM
- Form Factor
- SO-DIMM 204-pin
- Speed
- Non-ECC
- Unbuffered
- Compatible Slots
- 1 x memory - SO-DIMM 204-pin
- Designed For
- Acer Aspire 1551-32B2G32nrr, 1820PTZ-413G32 N, 1825PT-733G32ikk, 1825PT-734G32nkk, 1825PTZ-414G32n, 3935-744G25N, 5252-V560, 5334-333G32Mnkk, 5336-2281, 5336-2283, 5336-2524, 5336-2613, 5336-2754, 5336-2864, 5336-902G25MN - RET, 5336-902G32Mnrr, 5336-903G32Mn, 5336-T353G32Mnkk, 5551G-N833G32Mnck, 5551-P322G25MNKK, 5736Z-4016, 5736Z-4460, 5736Z-453G32MN, 5736Z-453G32Mnkk, 5736Z-454G32Mn, 5738G-653G25N, 5738G-662G25MN, 5741-353G32Mnsk, 5741G-434G50Mnsk, 5741G-434G64MNkk, 5742-3373G32MN, 5742-373G25MN, 5742-373G25Mnkk, 5742-374G32Mnkk, 5742-374G50Mnkk, 5742-5464G32Mncc, 5742-5464G50Mnkk, 5742-6248, 5742-6475, 5742G-374G32Mn, 5742G-374G50MN, 5742G-464G50Mn, 5742G-464G64MN, 5742G-5464G50MNKK, 5742G-5464G64Mnkk, 5742Z-4459, 5745-7833, 5745G-5453G32Mnks, 5745G-744G75MNKS, 5745G-7744G50MN - RET, 5745G-7746G64Mnks, 5745P-373G32Mnks, 5745PG-374G50Mn, 5745PG-374G50Mnks, 5745PG-384G50MN, 5745PG-5464G50Bnks, 5943G-374G50Mn, 5943G-464G50Mn, 5943G-5454G50Mns, 5943G-5464G64BNSS, 5943G-7748G64Wnss, 7551-3634, 7551G-N854G50MNKK, 7551G-N854G64Mnkk, 7551G-N934G32Mnck, 7551G-N934G50Mnkk, 7551G-P324G32MN, 7551G-P344G32MNKK, 7552G-N956G50MNKK, 7552G-X926G1TMnkk, 7552G-X926G64Bnkk, 7741-373G25MN, 7741G-374G50MN, 7741G-374G64Mn, 7741G-454G75MN, 7741G-464G75MN, 7741G-5464G32Mnkk, 7741G-6426, 7741G-7017, 7741ZG-P613G32MNKK, 7741ZG-P614G50MN, 7745G-464G1TMN, 7745G-464G64Mn, 7745G-464G75Bnks, 7745G-5464G1TMnks, 7745G-5464G32Mnks, 7745G-5464G50Mnks, 7745G-5468G1Mnks, 7745G-774161.5TMN, 8943G-373G32MN, 8943G-374G50Mnss, 8943G-464G64Mn, 8943G-464G75Bn, 8943G-464G75MN, 8943G-726G1TBn_TV, 8943G-728G1.5TWn_TV, 8943G-74161.5TWN, 8943G-744G50MN, 8943G-748G1.50TWN, 8943G-774161.5TWnss, 8943G-7744G75Bnss, 8943G-7748G1.5TBnss, 8943G-9429 , Acer Extensa 5635-652G25Mnkk, 5635G-652G32Mnkk , Acer TravelMate 5740-354G32MN, 5740-354G50Mn, 5740-433G32Mnss, 5740G-352G50Mnss, 5740ZG-P604G50Mn, 5740ZG-P613G32MN, 5740Z-P612G25MN, 6293-5B2G25N, 6293-663G32Mn_UMTS
