Kingston's industrial temperature microSD UHS-I has a wide operating temperature rating, making it suitable for harsh environments. It high operating temperature rating means it stands up to extreme heat in the desert and in test and measurement situations where standard microSD cards may fail, while its low operating temperature rating allows for use in below freezing weather, where equipment may be left outside for extended periods of time. Its high insertion rating is ideal for applications in which the card will be frequently accessed and removed from host devices, and its MLC NAND allows for large amounts of data to be written to the card.
With UHS-I speeds, the card is ideal for applications requiring greater bandwidth when recording large datasets. Higher sustained write speeds ensure data integrity by reducing transmission stutter, and the card also offers faster upload times when transferring files to a PC.
- Kingston - flash memory card - 16 GB - microSDHC UHS-I
- Product Type
- Flash memory card
- Form Factor
- microSDHC UHS-I Memory Card
- Storage Capacity
- 16 GB
- Speed Rating
- UHS Class 1 / Class10
- Technology
- MLC NAND Flash
- 5 years warranty
- Product Type
- Flash memory card
- Storage Capacity
- 16 GB
- Compatibility
- Non-specific
- SD Speed Class
- Read Rate
- Up to 90 MB/s
- Write Rate
- Up to 45 MB/s
- Form Factor
- Technology
- MLC NAND Flash
- Shockproof, waterproof, vibration-proof, X-ray-proof, temperature-proof
- Limited warranty - 5 years
- 11 mm
- 15 mm
- Thickness
- 1 mm
- -40 °C
- 85 °C
