Kingston Technology is the world's independent memory leader and is well-known for providing high quality memory products for HP servers, at an attractive price. Selecting the right memory for a server is as important as using the right memory manufacturer. Kingston system-specific HP server memory is designed to be ultra-reliable and reduce the total cost of ownership. Each Kingston memory module is designed, manufactured, tested and tailored to maximize the performance of a HP server system, and guaranteed to be compatible in that system. Kingston's system-specific server memory is ideal for customers who use HP servers and know the name and model number of their system.
Guaranteed compatibility
Kingston system-specific server memory is guaranteed to be compatible so you can rest assured you're getting the highest quality memory, tailored to your server. -
Quality and expertise
With more than a quarter of a century of server memory expertise, Kingston has the knowledge and resources to support your needs. Kingston engineers use only the highest quality components on the market to ensure maximum performance and legendary Kingston reliability.
- Kingston - DDR3 - module - 16 GB - DIMM 240-pin - 1600 MHz / PC3-12800 - registered
- Product Type
- Memory module
- Capacity
- 16 GB
- Memory Type
- DDR3 SDRAM - DIMM 240-pin
- Upgrade Type
- System specific
- Data Integrity Check
- ECC
- Speed
- 1600 MHz (PC3-12800)
- Registered
- OEM Manufacturer Equivalent Part Number
- HP 684066-B21, HP 672631-B21
- Limited lifetime warranty (Russia - 10 years)
- Designed For
- HPE ProLiant BL420c Gen8, BL460c Gen8, BL465c G7, BL660c Gen8, BL685c G7, DL160 Gen8, DL165 G7, DL360e Gen8, DL360p Gen8, DL380e Gen8, DL380p Gen8, DL385 G7, DL388p Gen8, DL585 G7, ML350e Gen8, ML350p Gen8, SL230s Gen8, SL250s Gen8, SL270s Gen8, WS460c Gen8
- Capacity
- 16 GB
- Upgrade Type
- System specific
- DRAM memory module
- Technology
- DDR3 SDRAM
- Form Factor
- DIMM 240-pin
- Speed
- ECC
- Registered
- Compatible Slots
- 1 x memory - DIMM 240-pin
- Designed For
- HPE ProLiant BL420c Gen8, BL460c Gen8, BL465c G7, BL660c Gen8, BL685c G7, DL160 Gen8 Base, DL160 Gen8 Entry, DL160 Gen8 Performance, DL165 G7, DL165 G7 Base, DL165 G7 Entry, DL165 G7 Performance, DL165 G7 Special Server, DL360e Gen8, DL360e Gen8 Base, DL360e Gen8 Entry, DL360e Gen8 Performance, DL360e Gen8 Special Server, DL360p Gen8, DL360p Gen8 Base, DL360p Gen8 CMS, DL360p Gen8 Entry, DL360p Gen8 High Performance, DL360p Gen8 Performance, DL360p Gen8 Special Server, DL380e Gen8, DL380e Gen8 Base, DL380e Gen8 Entry, DL380e Gen8 High Performance, DL380e Gen8 Storage, DL380p Gen8, DL380p Gen8 Base, DL380p Gen8 Entry, DL380p Gen8 High Performance, DL380p Gen8 Special, DL385 G7, DL385 G7 Base, DL385 G7 Entry, DL385 G7 Performance, DL388p Gen8 Base, DL585 G7, DL585 G7 Base, ML350e Gen8, ML350e Gen8 Base, ML350e Gen8 Entry, ML350e Gen8 Performance, ML350e Gen8 v2 Base, ML350p Gen8, ML350p Gen8 Base, ML350p Gen8 Entry, ML350p Gen8 Performance, ML350p Gen8 Special Server, SL230s Gen8 Base 1U Left Tray Server, SL230s Gen8 Base 1U Right Tray Server, SL250s Gen8 Base 2U Left Half Width Tray, SL250s Gen8 Base 2U Right Half Width Tray, SL270s Gen8 Base 4U Left Half Width Tray, SL270s Gen8 Base 4U Right Half Width Tray, WS460c Gen8
