Kensington Wall Laptop Power Adapter
Quicklinx: 87CCWS00 Mfr#: K38077EU
The Kensington Wall Laptop Power Adapter with USB Power Port is ideal whether you're looking for a replacement or a secondary power adapter for at home or on the move. It provides the reliability that you need and is compatible with a wide range of laptops.
Kensington Wall Laptop Power Adapter with USB Power Port - power adapter
Power adapter - external
Europe
Output connectors
1 x 4 pin USB Type A
Environmental Standards
ENERGY STAR
Europe
ENERGY STAR
