Kensington ClickSafe 2.0 Keyed Laptop Lock - Security cable - 1.8m
Quicklinx: DG6TWS00 Mfr#: K64435WW
Device Type: Laptop
Type: Security
Device Screen Size: [N/A]
Colour: Black, Silver
£53.94 ex VAT
£64.72 inc VAT
From the industry leader in physical device security for 25 years, Kensington's ClickSafe 2.0 Keyed Laptop Lock offers all the strength and one-click convenience and keyless engagement of the original, just in a smaller, uncompromised design. Featuring the 5mm keying system with anti-pick Hidden Pin Technology, the ClickSafe lock head snaps onto the ClickSafe Security Anchor after it has been installed into the Kensington Security Slot found in most laptops. A carbon steel cable deters cutting attempts and the pivot & rotate hinge prevents awkward angles when inserting the key.
Kensington ClickSafe 2.0 Keyed Laptop Lock - security cable
Security cable
Product Material
Carbon steel
Length
1.8 m
Pivot adjustment, ClickSafe Security Anchor, cut-resistant, hidden pin, rotatable
Security cable
Product Material
Carbon steel
Length
1.8 m
Limited warranty: - lifetime
Device Type: Laptop
Type: Security
Colour: Black
Colour: Silver
Brand: Kensington
