Make a MacBook or Ultrabook™ ultra productive
Ultrabooks™ and other super slim laptop computers like the Apple MacBook deliver sleek good looks. However, they usually come up short on ports for connectivity. As a result, you're constantly plugging and unplugging peripherals to connect to the devices you need. That's where the Kensington USB 3.0 Dual Docking Station comes in. It turns one USB port into six so that with one hot swappable USB connection you'll have access to all of your peripherals, including printer, external drive, scanner, keyboard & mouse, audio 2.0 speakers and even two 1080HD video monitors.
Nothing can boost productivity like a second monitor, and the Kensington USB 3.0 Dual Docking Station makes adding two big beautiful HD monitors as easy as connecting a single USB plug. What's more, the Dock's USB 3.0 ports allow super-speed data transfer of up to 5 Gbps and are backward compatible with USB 2.0. The USB 3.0 Dual Docking Station gives you a big productivity boost without taking up a lot of desktop space or sacrificing aesthetics. It features a slim design that complements today's Ultrabooks perfectly. There's even a security slot to lock it down with your Kensington lock. Turn your MacBook, MacBook Air or other super slim laptop into a productivity machine with the Kensington USB 3.0 Dual Docking Station.
- Optimized for Ultrabooks or MacBook to turn one USB port into 6
- Supports MAC OSX from V10.6 (Leopard) right up to the latest Mountain Lion releases
- Now also compatible with the MicroSoft Surface Pro
- Quick one-touch USB connection for hassle-free setup
- Corporate Install feature allows administrators to install the graphic driver over a MicroSoft® server
- High-speed data transfer of up to 5 Gbps
- Dual 1080p HD video for high quality video
- Faster network and Internet access with Gigabit Ethernet connection
- Audio 2.0 for enhanced sound
- Compatible with USB 3.0 and 2.0
- Slim, low-profile design
- DVI to VGA and DVI to HDMI conversions for greater monitor compatibility
- HDMI 1.3 supported
- Built-in security slot
- Kensington USB 3.0 Dual Docking Station (sd3500v) - docking station - USB - 1GbE
- Product Type
- Docking station
- Docking Interface
- USB
- 7.1 cm x 12.6 cm x 19.6 cm
- 770 g
- Black
- Localisation
- Europe
- Networking
- Gigabit Ethernet
- Power
- Power adapter
- 2-year warranty
- Product Type
- Docking station
- 7.1 cm
- 12.6 cm
- 19.6 cm
- 770 g
- Enclosure Colour
- Black
- Localisation
- Europe
- Data Link Protocol
- Gigabit Ethernet
- 4 x USB 2.0 - 4 pin USB Type A , 1 x microphone - input - mini-phone 3.5 mm , 1 x audio - line-out - mini-phone stereo 3.5 mm , 1 x video - DVI-Analog/Digital - 24+5 pin combined DVI , 1 x network - 10Base-T/100Base-TX/1000Base-TX - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 1 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x audio / video - HDMI - 19 pin HDMI Type A
- Cables Included
- 1 x USB cable - external
- Power Device
- Power adapter
- Limited warranty - 2 years
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
