Kensington NanoSaver Laptop Lock - Keyed
Quicklinx: G8BFWS00 Mfr#: K64444WW
Designed to fit the Kensington Nano Security Slot, the NanoSaver Keyed Laptop Lock secures ultra-thin laptops, tablets, and 2-in-1s with the same quality and strength that has made Kensington The Professionals' Choice for more than 25 years. Developed using strict specifications, patented technologies, and rigorous testing against tough environmental conditions, the NanoSaver Keyed Laptop Lock provides next generation security for ultra-thin devices.
  • Tough 10mm lock head with cleat locking technology
    Offering uncompromised security for select ultra-thin laptops built with the Kensington Nano Security Slot, the lock head is only 10mm in diameter and still meets the industry-leading testing standards for tamper-resistance, reliability and durability that only Kensington can provide.
  • Carbon steel cable
    Offering the same level of cut-resistance and theft-resistance as thicker cables, the carbon steel cable with plastic sheath offers security and greater mobility.
  • Pivot and rotate cable
    Special hinge creates great freedom of movement, eliminating awkward angles and allowing you to insert your key with complete ease.
  • Verified & tested
    Engineered to Kensington's rigorous specifications and third-party standards in torque/pull, foreign implements, lock lifecycle, corrosion, key strength and other environmental conditions.
Kensington NanoSaver Keyed Laptop Lock - security cable
Security cable
Package Content
Cable lock
Product Material
Carbon steel
Length
1.8 m
Cleat Locking Technology, hidden pin
Security cable
Product Material
Carbon steel
Package Content
Cable lock
Length
1.8 m
Thickness
5 mm
Limited warranty: - lifetime
