Kensington Ultimate Presenter with Virtual Pointer
Quicklinx: D5TXWS00 Mfr#: K75233EU
ABOUT THIS PRODUCT
The Kensington Ultimate Presenter with Virtual Pointer is an innovative presentation tool that works for a variety of environments and screens. Overcoming the shortcomings associated with traditional laser pointers, such as bright LED screens or safety restrictions, the Ultimate Presenter is optimised for use in conference rooms with TV displays, online meetings with remote participants and large auditoriums with multiple presentation screens. Complemented by versatile storage options and the KensingtonWorks software, the Ultimate Presenter is the ideal presentation tool for today’s digital world. Optimised to work with macOS, Windows,and leading presentation software such as PowerPoint, Keynote, Adobe PDF and Google Slides.
FEATURES
  • Virtual Pointer Technology works on a variety of presentation screens including traditional projection screens, TV displays, bright LED screens and smart boards, making it the ideal pointer for every presentation scenario, including conference rooms, online meetings and large auditoriums.
  • KensingtonWorks Software enables customisation of pointer size, shape and speed to suit your presentation environment, and additional options, such as configuring the blackout button to start and end the slide show.
  • Ergonomist approved design features a contoured shape to minimise wrist twist and maximise comfort with an intuitive 4-button layout.
  • 2.4GHz receiver with MicroSD card provides up to 20 metres (65ft) of wireless range, expandability to 32GB of memory and a plug & play user experience.
  • Windows and Mac compatible to support PowerPoint, Keynote, Adobe PDF and Google Slides
  • Storage Pouch conveniently stores your presenter in a soft travel pouch.
The pointer can be seen on a variety of presentation screens, including traditional projection screens, TV displays, LED screens and smart boards. Ideal for conference rooms with digital screens, online meetings with remote audiences,and large auditoriums with multiple display screens, this pointer overcomes the limitations of traditional laser pointers and allows you to present anywhere.
Personalise your clicker by customising the size, shape and speed of your pointer to suit your presentation environment, and adding additional options, such as configuring the blackout button to start and end the slide show.
Designed to maximise your comfort, the contoured shape reduces wrist twist and features an intuitive 4-button clicker to simplify your learning curve.
Offering you a plug & play user experience, the receiver MicroSD card provides up to 20 metres (65ft) of wireless range, expandability to 32GB of memory.
Supports leading presentation software, such as PowerPoint, Keynote, Adobe PDF and Google Slides to provide you flexibility in your digital world.
Storage Pouch
Conveniently store your presenter in a soft travel pouch while on the move.
  • Ergonomic design
    Crafted from acrylonitrile butadiene styrene (ABS), the Kensington Ultimate Presenter with Virtual Pointer is designed for durability and comfort, ensuring it can withstand frequent use while fitting comfortably in your hand.
  • Extended reach
    With a maximum operating distance of 20 m, this presentation remote control offers the freedom to move around the room, engaging with your audience without being tethered to your computer.
  • Seamless compatibility
    Designed to support personal computers, the Kensington Ultimate Presenter with Virtual Pointer integrates effortlessly with your existing setup, making it a versatile tool for a wide range of presentations.
Kensington Ultimate Presenter with Virtual Pointer presentation remote control
Presentation remote control
39.6 mm x 42.4 mm x 111 mm
58 g
Europe
Radio
Supported Devices
Personal computer
Wireless Technology
2.4 GHz
Max Operating Distance
20 m
3-year warranty
39.6 mm
42.4 mm
111 mm
58 g
Enclosure Material
Acrylonitrile butadiene styrene (ABS)
Europe
Radio
Wireless Technology
2.4 GHz
Supported Devices
Personal computer
20 m
Operating System
Apple Mac OS X, Windows 8.1, Windows 10
Carrying pouch, microSD Card (8GB), USB wireless receiver
Shipping Width
133.4 mm
Shipping Depth
73.66 mm
Shipping Height
202.2 mm
3-year warranty
