Chief upgraded fixed wall mounts based on installer feedback and direct observations of installers in the field. Many features join Fusion favorites like Centerless shift, ControlZone leveling adjustment and ClickConnect latching.
The benefits included added stability, faster install, improved lateral shift, easier cable management and enhanced security.
Installer-inspired Fusion fixed mount solves top flat panel installation problems, offering flexible adjustments for large displays with a low-profile display mounting solution.
Effortless adjustment
The Chief Fusion Large Adjustable Fixed Display Wall Mount features the innovative Centris Low-Profile Tilt, allowing for easy tilting of displays to achieve the perfect viewing angle without the need for tools. -
Secure installation
Equipped with ClickConnect Technology, this wall mount ensures a secure and effortless latch with an audible click to confirm that the flat panel is safely connected. -
Precise alignment
Controlzone Leveling and Centerless Shift provide precision during installation, offering horizontal and vertical adjustments for perfect positioning of your display. -
Versatile compatibility
Designed to support flat panel displays ranging from 42" to 86", this mounting kit is versatile for a wide array of display sizes, ensuring a perfect fit for your screen. -
Robust design
With a maximum load weight of 91 kg and compatibility with mounting stud centers up to 32", this wall mount is built to hold substantial displays securely.
- Chief Fusion Large Adjustable Fixed Display Wall Mount - For Displays 42-86" - Black mounting kit - for flat panel - black
- Product Type
- Mounting kit - wall-mountable
- Mounting Components
- Wall mount
- 88.3 cm x 5.1 cm x 46.4 cm
- Recommended Use
- Flat panel
- Recommended Display Size
- 42"-86"
- Max Mounting Pattern Size
- 871 x 400 mm
- Max Load Weight
- 91 kg
- Mounting Stud Centers
- 32", 16"
- Black
- 88.3 cm
- 5.1 cm
- 46.4 cm
- Black
AV Furniture
- Mounting kit
- Wall mount
- Recommended Use
- Flat panel
- Placing / Mounting
- Wall-mountable
- 871 x 400 mm
- 32", 16"
- 42"-86"
- Max Load Weight
- 91 kg
- Fixed, lateral shift, ClickConnect Technology, Controlzone Leveling, Centreless Shift, Centris Low-Profile Tilt
Smart Technologies Large Fusion Micro-Adjustable Fixed Wall Display Mount 37"
