Offering a precise, compact and versatile experience, the Orbit Wireless Mobile Trackball has everything mobile professionals need for comfort and productivity. It offers better ergonomics, with less wrist and hand movement that will ease the pain of repetitive-stress injuries. With no cables to tie you down, the 2.4 GHz wireless nano receiver works with either Windows or Mac when youre at home, on the road or in the office. Unique touch scrolling, along with the compact 32mm ball, lets you glide effortlessly through web pages and documents, and the nano receiver can be stored right inside the trackball.
- Kensington Advance Fit Wireless Mobile Trackball - trackball - 2.4 GHz - graphite, Ruby Red
- Trackball
- Connectivity Technology
- Wireless - 2.4 GHz
- Graphite, Ruby Red
- Orientation
- Right and left-handed
- 8.6 cm x 10.8 cm x 3.4 cm
- 180 g
- Localisation
- Europe
- Wireless Receiver
- USB wireless receiver
- Movement Detection Technology
- Laser
- Buttons Qty
- 2
- Battery
- 2 x AA type
- OS Required
- Apple MacOS X, Microsoft Windows Vista / XP / 7
- 5-year warranty
- Trackball
- Wireless Receiver
- Orientation
- 8.6 cm
- 10.8 cm
- 3.4 cm
- 180 g
- Localisation
- Europe
Input Device
- Wireless
- Interface
- 2.4 GHz
- Laser
- Buttons Qty
- 2
- Plug and Play
- AA type
- Installed Qty
- 2
- OS Required
- Limited warranty - 5 years
