Kensington Wired ValuMouse
Quicklinx: BZ8CWS00 Mfr#: K72110EU
Recommended Use: Leisure
Type: Mouse
Wired / Wireless: Wired
Colour: Black
Compatibility: Mac, PC
Hurry, only 3 left in stock!
£10.49 ex VAT
£12.58 inc VAT
The wired ValuMouse features a three-button/scroll wheel setup that offers silent clicking when you need to get work done and don't want to disturb anyone in a quiet environment. A high-definition optical sensor provides reliable and responsive control when you're navigating and the comfortable, contoured shaping feels great for either right-handed or left-handed users. It offers Plug & Play installation with a standard USB wired connection.
  • Silent click
    Significantly quieter than a standard mouse, it's ideal if you are using the device in a quiet environment, such as a library or at a conference presentation, and don't want to disturb others around you or interrupt your concentration
  • 1000 DPI sensor
    The high-definition optical sensor tracks the mouse's movements with smooth accuracy for optimal performance and productivity.
  • Ambidextrous design
    The three buttons with scroll wheel setup gives both right-handed and left-handed users the freedom to get the most out of the mouse with contours that allows for pain-free and comfortable extended usage.
  • Plug & Play installation
    Simply insert the standard USB wired connector into your device and you'll be up and scrolling quickly as the mouse driver will download and install automatically.
Kensington ValuMouse - mouse - USB - black
Mouse
Wired - USB
Orientation
Right and left-handed
6 cm x 10.8 cm x 3.8 cm
90 g
Movement Detection Technology
Optical
Buttons Qty
3
Movement Resolution
1000 dpi
Scrolling wheel, ambidextrous design
Apple MacOS X 10.5 - 10.8, Microsoft Windows 7 / 8 / 8.1 / 10
5-year warranty
Mouse
Orientation
6 cm
10.8 cm
3.8 cm
90 g
Input Device
Wired
USB
Optical
Buttons Qty
3
Movement Resolution
1000 dpi
1 x USB - 4 pin USB Type A
Plug and Play
Limited warranty - 5 years
Type: Mouse
Colour: Black
Compatibility: Mac
Compatibility: PC
Brand: Kensington
