Kensington N17 Laptop Lock - Like Keyed
Quicklinx: G8BWWS00 Mfr#: K64441L
The N17 Keyed Laptop Lock utilizes a unique lock engagement, creating a strong and reliable connection between the lock head and slot. The Keying System with anti-pick technology provides flexibility as part of Kensington's unparalleled robust custom keying solution for IT managers. A carbon steel cable deters cutting attempts and the pivot & rotate hinge diverts the cable away from other peripherals.
  • Unique lock engagement
    Expanding side "hooks" grab on to the internal sides of the non-standard lock slot, creating a strong connection between the device frame and the lock to resist and deter theft attempts.
  • Keying system
    A central pillar of Kensington's locking solutions, the exclusive keying system is common across all of Kensington's locks. The unparalleled custom management options provide flexibility, and the anti-pick Hidden Pin technology offers complete peace of mind. Now IT directors will only have one keying system to manage across their organization.
  • Carbon steel cable
    Offering the same level of cut-resistance and theft-resistance as thicker cables, the carbon steel cable with plastic sheath offers security and greater mobility with long cable.
  • Pivot and rotate cable
    Special hinge creates great freedom of movement, eliminating awkward angles and allowing you to insert your key with complete ease.
Kensington N17 Keyed Laptop Lock for Wedge Shaped Slots - security cable lock
Security cable lock
Package Content
2 x keys
Product Material
Carbon steel
Pivot adjustment, rotating, cut-resistant, hidden pin, 5mm Keying System, Tough Lock Head lock slot
Security cable lock
Product Material
Carbon steel
Package Content
2 x keys
Thickness
5 mm
