Kensington USB Lock W Cable Guard Square
Quicklinx: CRLBWS00 Mfr#: K67915WW
Device Type: Desktop Computer, Laptop, Other
Type: Security
Device Screen Size: [N/A]
Colour: Black / red
£35.80 ex VAT
£42.96 inc VAT
Reduce the risk of data leakage, data theft and unauthorized uploads with a solution that physically blocks USB ports from unauthorized access. The USB port lock with cable guard - square has the ability to block multiple adjacent ports, one with an active USB device such as keyboard or mouse with one lock, allowing continued secure use of authorized USB devices.
  • Enhanced security
    The Kensington USB Port Lock with Cable Guard - Square is designed to provide an effective solution for securing USB ports against unauthorized use. By blocking the port, it helps to prevent data theft and malware installation, ensuring that your PC remains protected.
  • Easy installation
    This USB port blocker is incredibly easy to install, requiring no technical expertise. Simply insert the blocker into the USB port and secure it with the included cable guard. This straightforward process makes it an ideal security measure for any PC.
Kensington USB Port Lock with Cable Guard - Square - USB port blocker
USB port blocker
Silver
USB port blocker
Silver
Interface Provided
Connector Provided
4 pin USB Type A x 1
Device Type: Laptop
Device Type: Other
Type: Security
Colour: Black / red
Brand: Kensington
