Kensington Laptop Cooling Stand
Quicklinx: BZ7WWS00 Mfr#: K62842WW
When it comes to keeping your laptop performing at its peak, theres no better way than with the Kensington Laptop Cooling Stand. Featuring dual fans powered via a USB cable, the stand lifts the laptop off the desktop to promote better air circulation to reduce heat buildup, which improves battery performance and extends its lifecycle. The stand also has a retracting stand and four rubber stability pads to help keep the laptop stable.
  • Enhanced cooling
    Equipped with built-in 2 cooling fans, this notebook stand efficiently dissipates heat, ensuring your laptop remains cool under heavy usage conditions.
  • Ergonomic design
    The tilt adjustment feature allows you to find the perfect viewing angle, reducing strain on your neck and wrists during long work sessions.
Kensington Laptop Cooling Stand - notebook stand
Notebook stand
Tilt adjustment, USB powered, built-in 2 cooling fans
Notebook stand
Limited warranty: - 2 years
