Kensington Anti-Glare and Blue Light Reduction Filter for 12.5" Laptops
Quicklinx: G86XWS00 Mfr#: 627551
£18.54 ex VAT
£22.24 inc VAT
Reduce glare and harmful blue light, and improve clarity with Kensington's Anti-Glare and Blue Light Reduction Filter for 12.5" Laptops. This filter reduces harmful blue light by up to 43%, and features an antimicrobial coating (matte side only) that inhibits bacteria growth by up to 99% (tested to JIS Z 2801 : 2010E for Escherichia coli and Staphylococcus aureus). An innovative anti-glare coating (matte side only) reduces reflection and improves clarity. Seamless attachment makes installation and removal easy and mess-free.
  • Reduces glare and harmful blue light
    Innovative anti-glare coating reduces reflection and improves clarity (matte side only). Filter eliminates blue light by up to 43%, easing eye strain and reducing the chances of interrupting sleep patterns.
  • Antimicrobial coating (matte side only)
    Inhibits bacteria growth by up to 99%.
  • Seamless attachment
    Makes installation and removal easy and mess-free.
  • Touch and pen enabled
    Allows you to use your device just as you would without a filter.
Kensington - notebook privacy filter
Notebook privacy filter
Installation Type
Removable
Transparent
Product Material
PET
27.7 cm 15.6 cm
15 g
Display Screen Size Compatibility
12.5"
Anti-reflective, antimicrobial finish, blue light cutting
Product Material
PET
27.7 cm
15.6 cm
Thickness
0.44 mm
15 g
25 cm x 0.5 cm x 36 cm / 552 g
12.5"
Transparent
Display Filter
Installation Type
Removable
Aspect Ratio
16:9
Limited warranty: - 2 years
Brand: Kensington
