When you need a compact, mobile mouse that offers Bluetooth wireless performance and comfort, the Kensington Pro Fit Bluetooth Mouse has everything you need to be productive. The Bluetooth connection allows you to save a USB port on your device for other accessories, which is extremely convenient on modern ultra-thin devices that have limited port space. The high definition 1000 DPI laser sensor lets you scroll around your screen with precision control. The two-button, scroll wheel design is highly intuitive and works equally well for both right-handed and left-handed users. And best of all, with simple and easy Pair & Play installation, youll be up and ready in no time.
Wireless convenience
Experience the freedom of wireless connectivity with Bluetooth 3.0, allowing for a clean, cable-free workspace and the flexibility to work from up to 10 m away. -
Precision tracking
Navigate with ease and accuracy thanks to the laser movement detection technology and 1000 DPI resolution, ensuring smooth and precise cursor control on a variety of surfaces. -
Ergonomic design
Designed for comfort, this mouse supports both right- and left-handed users, making it a versatile choice for any workstation. -
Energy efficient
With features like automatic power off and an on/off power switch, this mouse is designed to conserve battery life, ensuring you stay productive longer without frequent battery changes.
- Kensington Pro Fit Mobile - mouse - Bluetooth 3.0 - black
- Mouse
- Connectivity Technology
- Wireless - Bluetooth 3.0
- Black
- Orientation
- Right and left-handed
- 5.8 cm x 9.64 cm x 3.3 cm
- 80 g
- Movement Detection Technology
- Laser
- Buttons Qty
- 3
- Movement Resolution
- 1000 dpi
- Scrolling wheel, on/off power switch, automatic power off
- Battery
- AA type
- OS Required
- Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10, Apple MacOS X 10.9 - 10.11, Google Chrome OS 44
- 3-year warranty
- Mouse
- Orientation
- 5.8 cm
- 9.64 cm
- 3.3 cm
- 80 g
- Black
Input Device
- Wireless
- Interface
- Bluetooth 3.0
- Max Operating Distance
- Up to 10 m
- Laser
- Buttons Qty
- 3
- 1000 dpi
- AA type
- OS Required
- Limited warranty - 3 years
