Kensington Kensington Presenter Expert. Green Laser
Quicklinx: C1FYWS00 Mfr#: K72427EU
Own what professionals use to take control of the room and a laptops cursor with the Expert Wireless Presenter Expert with Green Laser Pointer, Cursor Control & 4GB Memory. The presenter stores your PowerPoint or Keynote files on the 4GB Micro SD card that fits into the wireless USB receiver. With a simple flick of a switch, you toggle between presentation and cursor control modes. Make your point with a green laser thats 10 times brighter than standard red lasers, ideal for bigger rooms and LED/LCD screens. The highly reliable 2.4GHz receiver resists device interference and gives you control from up to 150 feet away.
Kensington Presenter Expert Green Laser Presenter with Cursor Control and Memory presentation remote control - black
Presentation remote control
Enclosure Colour
135 mm x 75 mm x 205 mm
202 g
Europe
Radio
Max Operating Distance
50 m
Pointing device battery
3-year warranty
135 mm
75 mm
205 mm
202 g
Enclosure Colour
Europe
Radio
50 m
Low battery alert, built-in laser pointer, back-lit buttons, built-in 2 GB flash memory, power on/off
Operating System
Apple Mac OS, MS Windows 7, Windows 8
Carrying pouch
3-year warranty
