JBL Live 670NC headphones deliver powerful JBL Signature Sound in a comfortable on-ear headband style. When you're deep in your flow, True Adaptive Noise Canceling with Smart Ambient technology keeps you free from distractions. Then, when you want to keep an ear open to the world around you, you can stay aware as you continue listening to your favorite playlist - or even have a conversation without taking the headphones off. Easily access your preferred voice assistant with a tap on the ear cup to cue up a song, text your friend, check the weather, and much more. You'll enjoy 65 hours (50 hours with BT+ANC on) of music streaming. And if you still need more, a 5-minute speed charge gets you another four hours. The JBL Live 670NC can connect with two Bluetooth devices simultaneously, so you'll never have to miss a call, even if you're watching a movie on your tablet.
JBL Signature Sound and surround sound
Along with powerful JBL Signature Sound, the 40 mm drivers offer immersive JBL Spatial Sound that turns any stereo content from any device into virtual surround sound. -
Bluetooth 5.3 with LE audio supported
Wirelessly stream high-quality sound even at lower bit rates with the help of the Bluetooth technology. Audio Mode gets you the best available sound, while Video Mode makes sure the sound and visuals of your movies and games are always in sync. -
With four noise-sensing mics, True Adaptive Noise Canceling means zero distractions, whether it's time to focus on your studies or get lost in the groove. And if you want to hear the world around you without removing your headphones, Smart Ambient sharpens the sounds of your surroundings. -
Up to 65 hours of battery life and speed charge
For long-lasting fun, listen wirelessly for up to 50 hours and recharge the battery in as little as 2 hours with the convenient Type-C USB cable. And if you're in a hurry, a quick 5-minute recharge gives you 4 additional hours of music. -
Auto play and pause
Take the headphones off, the music stops. Put it back on, the music starts again. It genuinely couldn't be simpler. -
Multi-point connection
Effortlessly switch from one Bluetooth device to another. Jump from a video on your tablet to a call on your mobile phone, and never miss a moment. -
Seamless connectivity with any device
Whether you're using an Android or Windows device, it's easy to set up your headphones to automatically pair with it whenever it's nearby. -
2 beamforming microphones for calls
Your friends, family, and co-workers will hear every word you say - even if you're outside and it's windy. -
Comfort-fit fabric headband and carrying pouch
Soft ear cushions and a textured, fabric headband in earthly shades make these headphones comfortable and unique. And when you do take them off, they have a comfy and protective place to live that's easy to pull out of your bag.
- JBL LIVE 670NC - headphones with mic
- Product Type
- Headphones - Bluetooth - wireless, wired - 3.5 mm jack
- Compatibility
- Android phone, Windows, Android tablet
- Recommended Use
- Portable electronics
- Black
- Headphones Form Factor
- Full size
- Foldable
- Connectivity Technology
- Wireless, wired
- Wireless Technology
- Bluetooth
- Headphones Technology
- Dynamic
- Bluetooth Version
- Bluetooth 5.3
- Sound Output Mode
- Stereo
- Sound Effects
- Signature Sound, JBL Spatial Sound
- Audio Specifications
- Frequency Response 20 - 20000 Hz - Sensitivity 98 dB
- Impedance
- 32 Ohm
- Active Noise Canceling
- Microphones Included
- 2
- Controls
- On/off, answer/end, voice assistant
- Intelligent Assistant
- Google Assistant, Alexa
- 2-year warranty
- Product Type
- Compatibility
- 219 g
- Black
- Recommended Use
- Touch control
Audio Output
- Full size
- Foldable
- Dynamic
- Wireless, wired
- Bluetooth
- Bluetooth Version
- Bluetooth 5.3
- Bluetooth Profiles
- Hands-Free Profile (HFP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Sound Output Mode
- Stereo
- Sound Effects
- Active Noise Cancelling Technology
- True Adaptive Noise Canceling
- 20 - 20000 Hz
- Sensitivity
- 98 dB
- Impedance
- 32 Ohm
- Max Sound Pressure
- 95 dB
- Diaphragm
- 40 mm
- TalkThru technology, 2 devices connectivity, Ambient Aware, Auto Play, Auto Pause, Speed Charge, Smart Ambient
Microphone
- Form Factor
- Built-in
- 2
- Sensitivity
- -38 dBV/Pascal
- Audio Input Details
- Beamforming
Remote Control
- Controls
Tracking
- Sensors
- Touch sensor
- Connector Type
- Headphones (mini-phone stereo 3.5 mm)
Cable
- Detachable Cable
- Cable Length
- 2 m
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Included Accessories
- Carrying pouch, audio cable, USB-C charging cable
- Cable Details
- USB-C charge cable - detachable , Headphones cable - detachable - 2 m
- Battery
- Headphone battery rechargeable - Lithium Ion
- Capacity
- 850 mAh
- Run Time (Up To)
- 65 hour(s)
- Run Time Details
- Continuous playback (active noise-cancelling on) (noise cancelling ON / Bluetooth): up to 50 hours , Continuous playback (active noise-cancelling off) (noise cancelling OFF / Bluetooth): up to 65 hours , Continuous playback (active noise-cancelling on) (noise cancelling ON / cable connection): up to 40 hours , Continuous talk (active noise-cancelling on) (noise cancelling ON): up to 28 hours , Continuous talk (active noise-cancelling off) (noise cancelling OFF): up to 33 hours
- Recharge Time
- 3 hour(s)
- Limited warranty - 2 years
- 45 °C
