Stay in the groove all day long with stylish companions for work and play. JBL Live Pro 2 earbuds deliver hours of incredible JBL Signature Sound, speed charging, and Qi-compatible wireless charging for when your batteries need a boost. True Adaptive Noise Canceling eliminates distractions to give you totally immersive audio, while Smart Ambient keeps you alert to your surroundings. The stick closed design with Oval Tubes ensure better noise cancelation and enhanced audio quality for those who prefer a cleaner aesthetic. Got something to say? Make clear, perfect calls with 6 beamforming mics or access your preferred voice assistant for seamless handsfree control and connection wherever life's adventures take you.
JBL Signature Sound
Nothing beats incredibly clear music and calls from 11 mm dynamic drivers powered by JBL Signature Sound. -
True Adaptive Noise Canceling with Smart Ambient
True Adaptive Noise Canceling automatically adjusts to your surroundings, eliminating distractions for better sound wherever you are. Or use Smart Ambient when you need to focus on your environment, all without removing your earbuds. -
Hours of playback with wireless charging
Never miss a moment with hours of Qi-compatible battery life. Need a boost? Just 15 minutes of Speed Charge gives you another four hours of playtime - fast. -
6 mics for perfect calls with zero noise
Six beamforming microphones reduce wind and noise interference so your words always come through loud and clear. And with VoiceAware, you can choose how much of your own voice to hear by controlling the amount of mic input routed back into your earbuds. -
IPX5 water-resistant
Whether you're hitting the gym or caught in the rain, you won't have to worry. IPX5 means JBL Live Pro 2 headphones are water-resistant. -
Dual Connect and Sync with Multi-Point connection
Phone call in the middle of your favorite show? No problem. With Multi-Point connection, you can quickly and easily switch your headphone input from one Bluetooth device to another. You'll also enjoy quick, effortless pairing with any Android device as you shift between mono and stereo and your left, right, or both earbuds.
- JBL LIVE PRO 2 TWS - true wireless earphones with mic
- Product Type
- True wireless earphones - Bluetooth
- Recommended Use
- Portable electronics
- Silver
- Headphones Form Factor
- In-ear
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 5.2
- Sound Output Mode
- Stereo
- Sound Effects
- Signature Sound
- Audio Specifications
- Frequency Response 20 - 20000 Hz - Sensitivity 105 dB
- Impedance
- 16 Ohm
- Active Noise Canceling
- Microphones Included
- 6
- Intelligent Assistant
- Google Assistant, Alexa
- 1-year warranty
- Product Type
- True wireless earphones - Bluetooth - wireless
- Dimensions & Weight Details
- Earphone: 4.8 g , Charging case: 48.4 g
- Silver
- Recommended Use
- Touch control
- Protection
- IPX5, waterproof, sweat-resistant
Audio Output
- In-ear
- Connectivity Technology
- Wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 5.2
- Bluetooth Profiles
- Hands-Free Profile (HFP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Sound Output Mode
- Stereo
- Sound Effects
- Signature Sound
- Active Noise Cancelling Technology
- True Adaptive Noise Canceling
- 20 - 20000 Hz
- Sensitivity
- 105 dB
- Impedance
- 16 Ohm
- Diaphragm
- 11 mm
- Voice control, Google Fast Pair, Dual Connect + Sync Technology, Smart Ambient
Microphone
- Form Factor
- Built-in
- 6
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Included Accessories
- 3 sizes of soft in-ear plugs
- Cable Details
- USB-C charge cable
- IPX5
- Battery
- Headphone battery rechargeable - wireless charging
- Wireless Charging Standards
- Qi
- Included Qty
- 2
- Run Time (Up To)
- 10 hour(s)
- Run Time Details
- Continuous playback: up to 10 hours , Continuous playback (with included charging case): up to 40 hours
- Recharge Time
- 2 hour(s)
- Limited warranty - 1 year
