Like no other, the JBL Clip 3 is a unique ultra-portable, ultra-rugged and waterproof Bluetooth speaker that is small in size but with surprisingly big sound. The upgraded durable and fully integrated carabiner clips to your clothes, belt loop or backpack, making the Clip 3 your outdoor companion on every adventure.
Ultra-compact high-performance audio
The JBL Clip is small in stature but big in sound. With high performance compact driver the Clip can deliver your music as loud and clear as you needed, where ever you take it. -
Stream Bluetooth music and calls wirelessly and accurately
Stream your music or make a phone call - wirelessly - with the Clips built in Bluetooth. Its easy to set up and you can stream wirelessly from any tablet or smartphone. -
Ready-to-wear audio with integrated carabiner
With a rugged carabineer designed to hook onto your clothes, your backpack, or messenger bag, the JBL Clip keeps on-the-go pace with however fast you're going. The rugged make of the Clip also lends itself to resisting wear-and-tear while moving quickly: the portable speaker's protected by durable material with double injection housing that allows it to land safely and softly - even when it gets tossed into your backpack a little too roughly.
- JBL Clip 3 - speaker - for portable use - wireless
- Product Type
- Speaker - for portable use
- Protection
- Waterproof
- Speaker Type
- Active
- Continuous Power
- 3.3 Watt
- Frequency Response
- 120 - 20000 Hz
- Amplifier
- Integrated
- Bluetooth
- Speaker Details
- Speaker - mono - 3.3 Watt - 120 - 20000 Hz - active
- Grey
- Image Colour Disclaimer
- The displayed product image may be a different colour
- Battery
- Speaker battery rechargeable - Lithium Ion
- 9.7 cm x 4.6 cm x 13.7 cm
- 220 g
- 1-year warranty
- Product Type
- Hands-Free Function
- Protection
- Waterproof
- Enclosure Colour
- Grey
- Design Features
- Built-in carabiner clip
Speaker System
- Speaker Type
- Active
- Continuous Power
- 3.3 Watt
- 120 - 20000 Hz
- Signal-To-Noise Ratio
- 80 dB
- Amplifier
- Integrated
- Bluetooth 4.1
- Bluetooth Profiles
- Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Controls
- Power on/off, play/pause
Speaker System Details
- Speaker Details
- Speaker - mono - 3.3 Watt - 120 - 20000 Hz CFR - active
- Driver Details
- Speaker: full-range driver
- Included Accessories
- Micro-USB charging cable
- IPX7
- Max Depth of Water Resistance
- 1 m
- Rechargeable - Lithium Ion
- Capacity (Ah)
- 1000 mAh
- Run Time (Up To)
- 10 hour(s)
- Recharge Time
- 3 hour(s)
- 9.7 cm
- 4.6 cm
- 13.7 cm
- 220 g
- Limited warranty - parts and labour - 1 year
