Jabra Stealth, our debut next-generation Bluetooth headset is significantly smaller, lighter, more discreet and offers better comfort and longer talk time.
HD sound with noise reduction
Advanced Noise Blackout™ technology ensures clear, noise-free calls. Dual microphones reduce background noise, making you easy to hear. HD Voice* brings high-definition sound quality to both ends of the call.
Superior comfort in a small design
Stealth delivers superior comfort in a small design. The weight of the headset is perfectly balanced. It’s so discreet that you’ll hardly notice you’re wearing it.
Dedicated voice control button
Leave your phone in your pocket. Activate Siri and Google Now by tapping a dedicated button directly on the headset.
Stay connected with the nano sized bluetooth dongle
With a UC-compatible dongle, you can transfer calls from your softphone to your smartphone using the Jabra Stealth UC.
Optimised for Microsoft® Lync™, fully UC compatible
Voice Controls
Be notified and take control with your voice Jabra's intelligent Call Assist lets you take a call without a click. Built-in motion sensor technology turns the headset on when you pick it up or touch it, and automatically answers the call when you place it on your ear. If you are already wearing the headset, you can accept or reject a call using just your voice. -
Jabra Software Applications
Easy device configuration and softphone integration Customise and control your audio device settings with Jabra's software applications. You get full integration and remote call control with the latest generation of softphones. -
Intelligent Volume Control
Adjusts call volume automatically With Jabra intelligent volume control, you are now free from touching the volume control. The audio level adapts automatically to the interference noise around you, allowing you to hear what is being said wherever you are. -
Remote Asset Management
Remote mass deployment and device management Configure and implement the company's audio devices 100% remotely from one central point. You get the latest features and functionalities in one go with Jabra Xpress, a web-based solution. You can also get a complete overview of all Jabra audio devices installed in the IT network with Jabra Xpress' asset management component. -
Noise Blackout
Eliminate background noise interference Jabra noise blackout technology eliminates disturbing background noise such as wind, surrounding conversations or traffic to enhance your voice. So you can now talk freely without raising your voice excessively. -
Power Nap Mode
Automatically enters power nap mode With Jabra power nap mode, you can now leave your headset in the car or on your desk for days and still have it ready when you are. Your device automatically goes into sleeping mode when inactive. A great power management feature that gives you more talk time, less charging. -
HiFi Audio Streaming
Stream music, podcasts and GPS directions Jabra Bluetooth devices featuring A2DP allow you to stream music, podcasts, and even GPS directions in hi-fi quality to give you enhanced sound experience. -
Call Assist
Call Assist lets you take a call without a click Jabra's intelligent Call Assist lets you take a call without a click. Built-in motion sensor technology turns the headset on when you pick it up or touch it, and automatically answers the call when you place it on your ear. If you are already wearing the headset, you can accept or reject a call using just your voice. -
HD Voice - Wideband Audio
High quality audio for crystal clear conversations Enjoy high-definition sound with HD Voice and get crystal clear, intelligible communication. You get lifelike, vibrant conversations where you can focus on the content and don't have to struggle to understand what the person on the other end of the line is saying. -
UC Plug-And-Play
Plug-and-play with all leading UC platforms Jabra's intelligent Call Assist lets you take a call without a click. Built-in motion sensor technology turns the headset on when you pick it up or touch it, and automatically answers the call when you place it on your ear. If you are already wearing the headset, you can accept or reject a call using just your voice. -
Tap-To-Connect
Connects devices with a simple touch Near Field Communication technology (NFC) makes it easy for your Jabra device to instantly connect and interact with phones, tablets, and interactive tags. It requires no more than a simple touch. Just tap the phone and the Jabra device together and you are ready to talk or stream your music. -
Busylight
Avoid call interruptions with the Busylight indicator Jabra Busylight helps you to cope with the open office environment challenges and lets people clearly know you are on the phone. The indicator turns red when you are on a call and keeps you from being interrupted. -
Smartphone & Tablet Ready
Ready for use with the latest smartphones/tablets Your Jabra device is designed with future-ready technology to be fully compatible with the latest smartphones and tablets on the market. -
Multi-Device Connectivity
Manage all your calls from one single headset Multi-device connectivity technology lets you manage phone calls from several different devices such as deskphones, tablets, PCs and smartphones, with one single headset. You get greater flexibility and enhanced user experience. -
Jabra Connect
Customise your headset and control your devices The Jabra Connect app interacts actively with your headset and lets you customise your user experience to suit your preferences as well as control all your calls on multiple devices.
- Jabra STEALTH UC - headset
- Product Type
- Headset - Bluetooth - wireless - NFC
- Recommended Use
- Portable electronics, phone
- Headphones Form Factor
- In-ear - over-the-ear mount
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Headphones Technology
- Dynamic
- Bluetooth Version
- Bluetooth 4.0 EDR
- Impedance
- 32 ohm
- Active Noise Canceling
- Controls
- Volume, on/off, answer/end
- Intelligent Assistant
- Siri, Google Now
- 2-year warranty
- Product Type
- 1.53 cm
- 6.49 cm
- 2.49 cm
- 7.9 g
- Body Material
- Polycarbonate, silicone rubber, PC/ABS
- Recommended Use
- Max Operating Distance
- 30 m
Audio Output
- Dynamic
- Wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 4.0 EDR
- Bluetooth Profiles
- Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Phonebook Access Profile (PBAP)
- Active Noise Cancelling Technology
- Noise Blackout
- Impedance
- 32 ohm
- Diaphragm
- 11 mm
- Simultaneously Connectable Devices Qty
- 2
Microphone
- Form Factor
- Built-in
- Audio Input Details
- Omni-directional - 300 - 3400 Hz
Remote Control
- Controls
- Connector Type
- USB (5 pin Micro-USB Type B (power only))
Internet of Things (IoT)
- Siri, Google Now
- Included Accessories
- Bluetooth USB adapter, 2 earhooks, 2 EarGels ear tips
- Plug and Play, GOST, IC, FCC, RoHS, REACH
- Battery
- Headset battery rechargeable
- Run Time (Up To)
- 6 hour(s)
- Standby Time
- 240 hours
- Recharge Time
- 2 hour(s)
- Limited warranty - 2 years
Jabra USB-A to USB-C Adapter | In Stock | £14.99 |
Jabra Link 370 USB BT Adapter, MS Teams | In Stock | £53.21 |
