Jabra Evolve3 75 UC, Link 390 USB-A, Black, with Wireless Charging Pad
Quicklinx: JF6WWS00 Mfr#: 37599-989-989
Recommended Use: Conference
Connectivity: Wireless
£255.40 ex VAT
£306.48 inc VAT
From taking calls around the office to collaborating in cafés, modern work is fast, noisy, and always on the move. The new Jabra Evolve3 75 headset doesn’t just keep up, it makes you unstoppable. At just 180 grams, its sleek design sits gently on the ears for greater comfort and freedom of movement. AI-powered Jabra ClearVoice™ ensures your voice is heard with absolute clarity wherever you are, while Jabra Advanced ANC™ dynamically adjusts to your fit and surroundings for our most powerful noise cancellation yet. And with a pickup accuracy of more than 9 out of 10 words for AI, your prompts land first time—so you get answers instantly and easily without breaking your stride. Evolve3 75 is the perfect balance of voice clarity, immersive sound and freedom of movement, built for how you really work today. Get ready to become unstoppable.
Jabra Evolve3 75 UC - headset - USB-A via Bluetooth adapter - with wireless charging pad
Headset - Bluetooth - wireless - USB-A via Bluetooth adapter
Compatibility
Linux, Mac, Windows
Recommended Use
Conference - communication
Headphones Form Factor
On-ear binaural
Foldable
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.3 LE
Sound Output Mode
Stereo
Sound Effects
Spatial Audio
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 108.5 dB
Impedance
35 Ohm
Max Input Power
20 mW
Active Noise Canceling
Noise Isolating
Microphone Operation Mode
Digital MEMS
Microphone Noise Cancelling
Microphones Included
6
Controls
Mute, call, ANC/HearThrough, next/previous track, play/pause, power and connection status, voice assistant, volume
Intelligent Assistant
Siri, Google Assistant, Alexa
Environmental Standards
TCO Certified, generation 10, for headsets
Software Certification
UC certified, Zoom Certified, Google Meet Certified
Bundled with
Wireless charging pad
Compatibility
Linux, Mac, Windows
18.7 cm
15.1 cm
7 cm
180 g
Body Material
Metal, PC/ABS
Headband Material
Foam, stainless steel
Earpad Material
Dual foam fabric
Recommended Use
Over the air updates, ClearVoice microphone technology, Battery status indicator, replaceable battery, sleep mode, on/off switch, up to 8 devices pairing, wind noise reduction (WNR), 360° busylight, AI-ready, in-call LED indicator, Rapid Charge Technology
Protection
Encryption protection
Max Operating Distance
30 m
Bundled with
Audio Output
On-ear binaural
Foldable
Wireless
Wireless Technology
Bluetooth
Bluetooth Audio Codec
SBC, AAC, LC3
Bluetooth Version
Bluetooth 5.3 LE
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Serial Port Profile (SPP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Telephony and Media Audio Profile (TMAP), Public Broadcast Profile (PBP), Auracast, Low Energy
Sound Output Mode
Stereo
Sound Effects
Spatial Audio
Noise Isolating
Active Noise Cancelling Technology
Advanced ANC
Frequency Response
20 - 20000 Hz
Max Input Power
20 mW
Sensitivity
108.5 dB
Impedance
35 Ohm
Diaphragm
32 mm
Simultaneously Connectable Devices Qty
2
Volume Limiting Function
Audio prompts, MultiPoint Technology, Jabra Direct, Google Fast Pair, Auto Pause, Jabra Xpress, Microsoft Swift Pair, HearThrough, digital signal processing, super wideband (SWB), Auto resume, auto connect, IntelliTone technology, PeakStop technology, sidetone detection
Audio Output Details
Multimedia - 20 - 20000 , Communication - 100 - 14500
Microphone
Headset microphone
Digital MEMS
6
Sensitivity
-36 dBFS/Pa
Frequency Response
10 - 20000 Hz
Noise Cancelling
Clear Voice Technology
Remote Control
Controls
Tracking
Sensors
On-head detection
Connector Type
USB (24 pin USB-C)
Internet of Things (IoT)
Communications Technology
Bluetooth 5.3 LE
Carrying case, leaflet, wireless charging pad, USB-C to USB-C cable, Jabra Link 390a Bluetooth adapter, 3.5mm audio cable
Cable Details
USB-C to USB-C cable - 1.2 m
AES, MFI, G616
Sustainability Information
TCO Certified
Headset battery rechargeable - Lithium Ion - - wireless charging
Run Time (Up To)
110 hour(s)
Run Time Details
Continuous talk (active noise-cancelling/busylight off): up to 22 hours , Continuous talk (active noise-cancelling/busylight on): up to 18 hours , Continuous playback (active noise-cancelling on): up to 45 hours , Continuous playback (active noise-cancelling off) (with 10 min charge): up to 10 hours , Continuous playback: up to 110 hours , (with 5 min charge): up to 5 hour(s)
Recharge Time
180 min
Shipping Width
17.6 cm
Shipping Depth
20.5 cm
Shipping Height
5.9 cm
-10 °C
45 °C
Min Storage Temperature
-10 °C
Max Storage Temperature
50 °C
Brand: Jabra
