Jabra Speak 750 MS Teams USB/BT & Link 370
Quicklinx: FL14WS00 Mfr#: 7700-309
£193.32 ex VAT
£231.98 inc VAT
Marketing description is not available.
  • Hear and be heard when it matters
    Hold completely natural conversations via speakerphone as both sides of the conversation are transmitted at the same time, allowing conversations to flow just as they do in person.
  • Certified for Microsoft Teams
    Built to fit in with the way the modern world works, the Microsoft Teams variant has a dedicated LED button that flashes for notifications. Tap to join meetings and use it to see when you have missed calls or voicemails.
  • Works with all leading UC platforms
    Versatile and easy to use and compatible with all leading Unified Communications platforms. Certified for use with UC, for an accessible, seamless connection experience and maximum flexibility when connecting with colleagues around the world. Enjoy a seamless meeting experience, whatever platform you're using.
  • Plug-and-play for instant collaboration
    Simply being able to plug-and-play to your laptop, smartphone or tablet, using either USB or Bluetooth, makes collaboration so much easier.
Jabra SPEAK 750 MS - speakerphone - USB
Speakerphone - Bluetooth - wireless - USB
Recommended Use
Portable electronics, phone, computer, conference
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 4.2
Sound Output Mode
Mono
Signal-To-Noise Ratio
70 dB
Microphone Operation Mode
Omni-directional
Controls
Mute, volume, answer/end
301 g
Recommended Use
Max Operating Distance
30 m
Audio Output
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 4.2
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Sound Output Mode
Mono
70 dB
Acoustic echo cancelation
Microphone
Built-in
Omni-directional
Remote Control
Controls
Jabra Link 370 USB Adapter, soft pouch
Cable Details
USB cable - 90 cm
Plug and Play
Hands-free battery rechargeable
Run Time (Up To)
10 hour(s)
Recharge Time
3 hour(s)
Brand: Jabra
