Jabra SPEAK 510 MS Bluetooth Speakerphone
Quicklinx: 8G6RWS00 Mfr#: 7510-109
More than 50 In Stock
£83.33 ex VAT
£99.99 inc VAT
The Jabra Speak 510 is a portable speakerphone that gives you the power to turn any room into a conference room. Regardless of your location and your timeline, you can now join the conversation anytime, anywhere.
Slim and compact design
Get the perfect solution for audio conferencing on demand with a compact and lightweight design, an integrated USB cable management for quick set-up and a protective travel case.
Plug-and-play solution
Plug your USB cable or connect via Bluetooth®, and simply connect Jabra Speak to your PC, tablet or smartphone. That's it. You are ready to dial in.
Outstanding sound quality
To get crystal-clear and natural sounding calls that allow attendees to hear and speak clearly across any location.
Unlimited mobility
Choose Jabra Speak 510 enhanced with Bluetooth to connect to any mobile device and get the freedom to communicate on your terms.
Optimal user experience
Benefit from full compatibility - including call control, with the leading UC/Softphone solutions and any Bluetooth enabled cell phone, smartphone or tablet.
  • Hold meetings wherever you go
    A compact portable design lets you hold conference calls anywhere.
Jabra SPEAK 510 MS - VoIP desktop speakerphone - USB
VoIP desktop speakerphone - Bluetooth - wireless - USB
Compatibility
Windows
Recommended Use
Portable electronics, computer - communication
Additional Functions
DSP, LED lights
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 3.0
Sound Output Mode
Mono
Sound Effects
Crystal Clear
Audio Specifications
Frequency Response 250 - 14000 Hz
Microphone Operation Mode
Omni-directional
Controls
Mute, volume, answer/end
Intelligent Assistant
Siri, Cortana, Google Assistant
Software Certification
Certified for Skype for Business
Compatibility
Windows
DSP, LED lights
12 cm
12 cm
3.3 cm
195 g
Recommended Use
Max Operating Distance
30 m
Audio Output
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 3.0
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio Gateway Hands-Free Profile (AGHFP)
Sound Output Mode
Mono
Sound Effects
Crystal Clear
Frequency Response
250 - 14000 Hz
Diaphragm
50 mm
Simultaneously Connectable Devices Qty
2
Voice guidance
Microphone
Built-in
Omni-directional
Frequency Response
150 - 6500 Hz
Audio Input Details
Omni-directional - 150 - 6500 Hz
Remote Control
Controls
Connector Type
USB 2.0 (4 PIN USB Type A)
Cable
Cable Length
90 cm
Internet of Things (IoT)
Carrying pouch
Cable Details
USB cable - 90 cm
Plug and Play, IC, FCC, KCC, TELEC, SRRC, NCC, RCM
Rechargeable - Lithium Ion
Run Time (Up To)
15 hours
Recharge Time
2 hour(s)
Shipping Width
13.25 cm
Shipping Depth
14.3 cm
Shipping Height
4.55 cm
8G6R Jabra Secure Mount For Speak 410/510 In Stock £1.64
Resources
The following resources are available for the Jabra SPEAK 510 MS Bluetooth Speakerphone
Type: VoIP conferencing system
Brand: Jabra
