The Jabra PRO 9450 dual connectivity headset is a user-friendly, no-frills device which provides office staff with a straightforward interface to handle calls from both desk phones and UC softphones. It is therefore ideal for companies in transition to UC, or indeed any organization using a combination of these two types of phones. With Jabra PRO 9450, everyone has an opportunity to benefit from true wireless working and enhanced productivity!
Exceptional audio clarity
With a frequency response of 150 - 6800 Hz and Noise Blackout technology, the Jabra PRO 9450 Replacement headset ensures every conversation is heard with clear clarity, whether in a noisy office or a quiet room. -
Wireless freedom
DECT wireless technology provides a robust connection with up to 150 m operating distance, offering the freedom to move around the office without losing call quality. -
All-day comfort
Designed for prolonged use, the on-ear headphones with a 28 mm diaphragm are lightweight and comfortable, ensuring you can focus on your calls without discomfort. -
Advanced call management
Equipped with intuitive controls for answer/end, mute, and volume directly on the headset, managing calls is seamless, enhancing productivity and convenience. -
Long-lasting battery life
The rechargeable battery offers up to 38 hours of standby time and can be fully recharged in just 2 hours, ensuring the headset is ready when you are.
- Jabra PRO 9450 Replacement - headset - replacement
- Product Type
- Headset - replacement - DECT - wireless
- Recommended Use
- Portable electronics, phone, computer - communication
- Additional Functions
- DSP
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wireless
- Wireless Technology
- DECT
- Sound Output Mode
- Mono
- Sound Effects
- Crystal Clear
- Audio Specifications
- Frequency Response 150 - 6800 Hz - Sensitivity 93 dB
- Impedance
- 32 Ohm
- Active Noise Canceling
- Microphone
- Boom
- Microphone Noise Cancelling
- Controls
- Mute, volume, answer/end
- Designed For
- PRO 9450, 9450 Duo, 9450 Duo NCSA, 9450 Flex
- Product Type
- Headset - DECT - wireless
- Replacement
- DSP
- 4.8 cm
- 13 cm
- 1.8 cm
- 28 g
- Recommended Use
- Max Operating Distance
- 150 m
Audio Output
- On-ear
- Wireless
- DECT
- Sound Output Mode
- Mono
- Sound Effects
- Crystal Clear
- Active Noise Cancelling Technology
- Noise Blackout
- 150 - 6800 Hz
- Sensitivity
- 93 dB
- Impedance
- 32 Ohm
- Diaphragm
- 28 mm
- SafeTone technology, PeakStop technology
Microphone
- Boom
- Form Factor
- Headset microphone
- Sensitivity
- -30 dB
- 150 - 6800 Hz
- Noise Cancelling
- Audio Input Details
- Uni-directional - 150 - 6800 Hz
Remote Control
- Controls
- Plug and Play, UL, NOM, CB, IC, PSB, FCC, TELEC, EAC, ICASA, NTC, ACMA, SIRIM
- Battery
- Headset battery rechargeable
- Run Time (Up To)
- 10 hour(s)
- Standby Time
- 38 hours
- Recharge Time
- 2 hour(s)
- Designed For
- Jabra PRO 9450, 9450 Duo, 9450 Duo NCSA, 9450 Flex
