Jabra Motion UC Skype for Business Bluetooth Headset
Quicklinx: CLHHWS00 Mfr#: 6630-900-300
The Jabra Motion UC's intuitive controls, motion sensing technologies, quick NFC pairing and incredible 100 metres range from the PC, make it a smart, stylish choice for mobile professionals. Optimised for Microsoft Lync.
Jabra is the ultimate headset for Unified Communications that allows you to communicate easily, both in the office and on the go.
Jabra Motion UC MS, optimized for Microsoft Lync, is second to none in terms of innovative features and future proof technology. When used with your UC client you get full integration, including automatic updating of your UC presence status when on a smartphone call. The headset's Busylight indicator also ensures that you avoid interruptions.
  • Superior sound
    Get best-in-class sound quality. Built-in motion sensor and advanced microphones adapt the sound to your surroundings. Enjoy crystal-clear, high-definition calls even in noisy or windy conditions.
  • All-day comfort
    Get maximum comfort with a behind-the-ear design and flexible materials that hug your ear. Find the perfect fit by adjusting the speaker and flipping it to fit either ear.
  • Smart motion sensor
    Answer calls by simply picking up the headset. When lying still, the motion sensor activates a "Power Nap" mode to save battery. Lift the headset, and it's ready to go again.
Jabra Motion UC MS - headset
Headset - Bluetooth - wireless - NFC
Recommended Use
Portable electronics, computer
Headphones Form Factor
Ear-bud - over-the-ear mount
Wireless
Wireless Technology
Bluetooth
Headphones Technology
Dynamic
Bluetooth Version
Bluetooth 4.0 EDR
Audio Specifications
Frequency Response 150 - 6500 Hz
Impedance
16 Ohm
Active Noise Canceling
Microphone
Boom
Controls
Volume, answer/end, microphone on/mute
1.45 cm
10.2 cm
7 cm
17.5 g
Body Material
Polycarbonate, PC/ABS
Recommended Use
Max Operating Distance
100 m
Audio Output
Dynamic
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 4.0 EDR
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP)
Active Noise Cancelling Technology
Noise Blackout
Frequency Response
150 - 6500 Hz
Impedance
16 Ohm
Microphone
Boom
Audio Input Details
Omni-directional - 150 - 6500 Hz
Remote Control
Controls
Tracking
Sensors
Motion sensor
Wireless Link
Transmission Range
100 m
Car power adapter, Bluetooth USB adapter, 3 pairs of gel ear tips
Cable Details
USB cable
Headset battery rechargeable
Run Time (Up To)
7 hour(s)
Standby Time
360 hours
Recharge Time
2 hour(s)
