Jabra Handset 450 for Cisco combines the comfort of a wireless phone experience with the many advantages of a UC solution. Offering plug-and-play installation, superior audio quality and remote call control, the wireless Jabra Handset 450 for Cisco is the perfect complement to Cisco Jabber for Virtual Environments. Fully integrated to support the softphone's call control features remotely, it lets you choose the way you want to work!
Crystal-clear sound
Handset 450 integrates wideband audio to give you a crystal-clear and natural sound experience, guaranteeing that you won't miss any details. The noise-cancelling microphone will eliminate any background noise and ensure that you are always heard. -
Wireless, secure and simple
Jabra Handset 450's plug-and-play solution ensures that installation is truly hassle-free. Wireless DECT technology allows you take the call anywhere in the office, with up to a 20 m range. High security DECT encryption and physical pairing, (rather than over the air) safeguards superior transmission security. -
You're in control
Several Handset 450 features enhance user convenience, allowing you to have firm control. Lift the handset to answer a call. Put it back in the cradle to end it. Easy controls allow you to mute calls and adjust volume. A beep tone will let you know if there is a call waiting. The rechargeable battery gives you up to 15 hours of talk-time. -
Supported platforms
Works with most softphones such as Skype for Business (Lync) and is certified for Cisco Jabber .
- Jabra 450 - VoIP handset
- Product Type
- VoIP handset - Wi-Fi - wireless
- Dark
- Connectivity Technology
- Wireless
- Wireless Technology
- Wi-Fi
- Microphone
- Built-in
- Microphone Operation Mode
- Omni-directional
- Controls
- Mute, volume
- Product Type
- Dimensions & Weight Details
- Handset: 4.4 cm x 20.3 cm x 4.7 cm / 185 g , Cradle: 5.7 cm x 21.1 cm x 3.6 cm / 175 g
- 5.7 cm
- 21.1 cm
- 6 cm
- 360 g
- Dark
- Max Operating Distance
- 20 m
Audio Output
- Wireless
- Wi-Fi
- Diaphragm
- 28 mm
Microphone
- Omni-directional
Remote Control
- Controls
- Mute, volume
Wireless Link
- Transmission Range
- 20 m
- Connector Type
- USB (4 PIN USB Type A)
- Included Accessories
- Cradle
- Cable Details
- USB cable
- Plug and Play
- Battery
- Handset battery rechargeable
- Run Time (Up To)
- 15 hour(s)
- Standby Time
- 120 hours
- Recharge Time
- 3 hour(s)
Jabra USB-A to USB-C Adapter | In Stock | £14.99 |
