Jabra GN2100 Duo Telecoil NC Wired Headset (Hearing Aid Users Only)
Quicklinx: 6JLNWS00 Mfr#: 2127-80-54
The GN 2100 Telecoil is the state-of-the-art, professional headset for hearing aid wearers. It is equipped with a hearing aid-compatible telecoil, suitable for all standard telecoil-equipped hearing aids and fitted to the plain side of the earpiece. The telecoil cancels out surrounding background noise and heightens the sound quality from the telephone for clearer, crisper phone conversations.
  • Telecoil-equipped headset for those with special hearing needs
  • Filters out unwanted background noise with noise canceling microphone
  • Ultra lightweight for all-day wearing comfort
  • Only one side of the headset works for sound
This headset does NOT include a bottom cord
For use with hearing aids only
  • Multiple wearing options
    Wear it exactly the way you want. Choose from four different wearing styles: headband, behind the neck, ear hook or ear loop. Comes with a selection of ear plates and ear cushions.
  • Noise-cancelling microphones
    Make yourself heard. Advanced noise-cancelling microphones filter out ambient noise and make sure only your voice comes through.
  • Stylish & comfortable design
    GN2100 looks great and is built for comfort. Its lightweight frame and adjustable boom-arm guarantee the perfect fit for all-day wear.
  • PeakStop?
    PeakStop? instantly removes any harmful loud sounds before they even reach your ears. This keeps the sound level in the safe range and protects your hearing.
  • Talk in Comfort
    Find the perfect fit with a range of light, ergonomically designed frames, soft ear cushions, adjustable headbands and microphone boom. Your headset will be comfortable all day long.
Jabra GN 2100 Telecoil - headset
Headset - wired
Recommended Use
Phone
Headphones Form Factor
On-ear binaural
Wired
Headphones Technology
Dynamic
Microphone
Boom
Microphone Operation Mode
Mono
Headset - wired
Recommended Use
Phone
Audio Output
On-ear binaural
Dynamic
Wired
Microphone
Boom
Mono
6JLN Jabra GN1200 Smartcord (Curly) - for Desk Phone Connectivity In Stock £28.95
6JLN Jabra LINK 860 Amplifier In Stock £128.47
6JLN Jabra GN1216 - headset cable - 2 m In Stock £30.13
Resources
The following resources are available for the Jabra GN2100 Duo Telecoil NC Wired Headset (Hearing Aid Users Only)
