Jabra Evolve 75e UC Wireless Earbuds
Quicklinx: D77KWS00 Mfr#: 7099-823-409
Engineered to be the world's first professional UC-certified wireless earbuds, the Jabra Evolve 75e combines Skype for Business certification, incredible Active Noise Cancellation, a host of professional features found in the Jabra Evolve series, and a wearing style popular with mobile office workers.
The Evolve 75e fully charges in just two hours, and the best-in-class battery provides up to 14 hours of power. Five control buttons provide easy access to calls and music, and include a smart button for one-touch access to Siri® and Google Now™. All-day comfort is provided with multiple fittings for gels and earwings.
Professional Sound. The way you want to wear it.
UC certified three microphone technology creates a unique talk-zone, and with an around-the-neck, wireless earbud design.
Powerful at work. Fully concentrate whatever the noise around you.
Focus with Active Noise Cancellation, and an integrated busy-light lets colleagues know you are not to be disturbed.
Last as long as you need it. All day long.
Enjoy up to 14 hours of battery life on just a single charge - and fully charge the earbuds in just 2 hours.
  • Professional sound
    Skype-certified 3-microphone technology creates a unique talk zone, making sure you're heard, while other nearby voices are filtered out. With an around-the-neck, wireless earbud design.
  • Powerful at work
    Focus with Active Noise-Cancellation and an integrated busylight lets colleagues know you are not to be disturbed.
  • Calls and music that last for as long as you need them to
    The Evolve 75e fully charges in just two hours and that best-in-class charge provides up to 14 hours of battery life.
  • Multiple fitting options
    Personalised fit for an improved experience. Multiple fitting options for EarGels and EarWings give amazing comfort throughout the day.
  • Smart controls for work and play
    Five buttons for quick control of calls and music, including a smart button for one-touch access to Siri and Google Now and a vibrating neckband to provide silent notifications.
Jabra Evolve 75e UC - earphones with mic - USB
Earphones - Bluetooth - wireless - USB
Recommended Use
Portable electronics, computer - communication
Headphones Form Factor
In-ear - behind-the-neck mount
Wireless
Wireless Technology
Bluetooth
Headphones Technology
Dynamic
Bluetooth Version
Bluetooth 4.2
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz
Active Noise Canceling
Noise Isolating
Microphone
On-cable
Microphones Included
3
Controls
Volume, answer/end, play/pause, next/previous track, reject call
17.6 cm
18.6 cm
5.4 cm
50 g
Body Material
Silicone
Recommended Use
Vibrating call alert
Protection
Waterproof, sweat-resistant, IP54
Max Operating Distance
30 m
Audio Output
Dynamic
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 4.2
Sound Output Mode
Stereo
Noise Isolating
Active Noise Cancelling Technology
Hybrid ANC
Frequency Response
20 - 20000 Hz
Diaphragm
15 mm
In-Cord Volume Control
Simultaneously Connectable Devices Qty
2
Voice guidance, magnetic ear buds, Busy light, Jabra Direct
Microphone
On-cable
3
Frequency Response
150 - 6800 Hz
Remote Control
Controls
Connector Type
USB (power only)
Protective case, leaflet, Jabra Link 370 USB Adapter, EarGels and EarWings pack (S/L size)
Cable Details
USB cable - 1.5 m
Headphone battery rechargeable
Run Time (Up To)
14 hour(s)
Recharge Time
2 hour(s)
