The Jabra Dial 550 delivers all the convenience of a handset to your favourite softphone application with a simple plug-and-play USB connector. Enable conference calls quickly and easily with the touch of a button and enhance your collaboration capabilities. Instantly take advantage of all softphone functionality with the handset convenience you desire.
Easy and intuitive handset for Unified Communications
With the Jabra Dial 550 you can quickly take advantage of the collaboration capabilities that Unified Communications and softphone platforms provide. It delivers standard handset features, familiar functionality and comes with a handy flip stand that keeps your handset nearby and protects it when you are on the go. You can even hear incoming calls when your computer is locked or muted. -
Seamless integration with all leading Unified Communications systems
Easy USB plug-and-play connection integrates with all leading Unified Communications systems. -
True HD Voice/wideband audio performance
The Jabra Dial 550's HD Voice/wideband audio and omni-directional microphone deliver lifelike audio quality for low noise environments. -
Turns any call into a conference call
Access and join conference calls whenever you want and wherever you are. Use the Jabra Dial 550 handset as a quality speakerphone with just the touch of a button. It's lightweight and easy to handle with dedicated keys. -
Omni-Directional Microphone
Jabra products with omni-directional microphones pick up sound equally well from all directions. Ideal for conference calls to get lifelike and natural-sounding conversations in environments with low or no background noise, with 360 degree coverage. -
UC Plug-And-Play
Jabra's intelligent Call Assist lets you take a call without a click. Built-in motion sensor technology turns the headset on when you pick it up or touch it, and automatically answers the call when you place it on your ear. If you are already wearing the headset, you can accept or reject a call using just your voice.
- Jabra DIAL 550 - USB VoIP phone
- Product Type
- USB VoIP phone
- Speakerphone
- Display
- LCD display - monochrome
- 1-year warranty
- Product Type
- USB VoIP phone
Phone Features
- Dialer Type
- Keypad
- Dialer Location
- Handset
- Conference Call Capability
- Speakerphone
- Menu Operation
- Indicators
- Visual ringer light
IP Telephony
- VoIP
- Voice Features
- HD Voice
Display
- Display Location
- Handset
- Included Accessories
- Stand
- Plug and Play
- Technology
- Rechargeable
- Limited warranty - parts and labour - 1 year
Jabra USB-A to USB-C Adapter | In Stock | £14.99 |
