Full mobility is the word! The IRISCard Corporate 5 is a professional and multi-user solution enabling on-the-go users to easily capture information from their business contacts when away from their computer. Ideal for today's mobile lifestyle, it turns contact management into a child's play.
The business card is simply zipped through the cordless, battery-powered scanner, and the scanned image is then either saved in the built-in memory, on an SD card or on a standard USB key. Once back in the office simply insert the SD card into your computer, and the scanned business cards are automatically processed by the Cardiris Corporate software and exported to the Cloud (Salesforce, Google Contacts), Microsoft Dynamics CRM (online and offline), Outlook, ACT!, etc.
- IRIS IRISCard Corporate 5 - sheetfed scanner - portable - USB
- Sheetfed scanner - portable
- Interface Type
- USB
- Max Supported Document Size
- 105 x 152.4 mm
- Input Type
- Optical Resolution
- 300 dpi
- Max Document Size
- 105 mm x 152.4 mm
- Supported Document Type
- Business card
- Document Feeder Type
- Manual
- Flash Memory
- 512 MB
- Battery
- 1 x lithium polymer
- System Requirements
- Apple MacOS X 10.4 or later, Microsoft Windows Vista / XP / 7
- 15.8 cm x 5.4 cm x 4.3 cm
- 250 g
- Interface Type
- USB
- 105 x 152.4 mm
Scanner
- Input Type
- 300 dpi
- Scanner Features
- Powered by USB port
Media Handling
- Max Document Size
- 105 mm x 152.4 mm
- Business card
- Manual
- Flash Memory
- 512 MB
- Supported Flash Memory Cards
- Memory Stick PRO, SD Memory Card, xD-Picture Card
- Interfaces Details
- USB - Type A , USB - Mini-B
- Included Accessories
- Cleaning brush, calibration card
- Cables Included
- 1 x USB cable
- Battery Installed
- Run Time (Up To)
- 150 pages
- Software Included
- Evernote Premium (1 year subscription), Cardiris Corporate (5 users license)
- OS Required
- System Requirements Details
- Windows XP/Vista/7 - Pentium HD 300 MB , MacOS X 10.3.9 or later - PowerPC G3 HD 160 MB
- 15.8 cm
- 5.4 cm
- 4.3 cm
- 250 g
