ioSafe 2TB Solo Disaster Proof USB 2.0 Desktop Hard Drive
Quicklinx: 7V4SWS00 Mfr#: SL2000GB1YR-EU
See The ioSafe Solo Disaster Proof Hard Drive in Action on the BBC!
The world's first affordable high capacity disaster-proof hard drive.
The ioSafe Solo hard drive is the simplest and safest way to backup and store data from your entire PC, Mac, laptop or NAS. Wrapped in elegant design and packed full of intense technology, the ioSafe Solo + 12 month Data Recovery Service (DRS) is a virtual fortress for data. Combining an array of patented, proprietary technology the ioSafe Solo + DRS delivers unparalleled protection for home users and small businesses.
  • Fireproof - Protects data from loss up to 1550°F for 1/2 hour per ASTM E119
  • Waterproof - Protects data from loss up to 10ft for 72 hours
  • Data Recovery Service - Up to $1000 for forensic recovery
  • USB 2.0 Connectivity
  • Mac and PC Compatible
Product Specifications
  • Fireproof: Protects against data loss in fire up to 1550ºF,1/2 hour Per ASTM E119
  • Waterproof: Protects data from flood, full submersion, 10' depth, 72 hours fresh or salt water
  • Data Recovery Services: Up to $1000 for forensic data recovery
  • PC/Mac Compatibility: USB 2.0 provides full support for windows XP, Vista, Windows 7 and Mac
  • Theftproof: Physical theft protection cable lock or floor mount option
Operational Details
  • Single disk, up to 2TB storage capacity available
  • Quiet forced air cooling
  • Multi-platform compatibility: Windows and Mac
  • USB 2.0, up to 480Mb/s
Disaster & Security Specifications
  • Fire protection: 1550F, ½ hr per ASTM E119
  • Flood / submersion protection: to 10 feet water depth, 3 days.
  • Tested per UL, FCC and CE Standards
  • Proven data protection and recovery. Tested to ASTM E119 standards for fire exposure.
  • Physical theft protection: Cable lock or floor Mount capable
Support
  • 1 Year Data Recovery Service Standard (3 and 5 year plans available)
  • 3 Year manufacturer's warranty for defects Standard (5 year available with purchase of 5 year DRS upgrade)
Inside The Box
  • ioSafe Solo USB External Hard Drive
  • USB 2.0 Cable
  • Power Supply
  • Owners Manual and Warranty
Electrical
  • Electrical -- AC input
  • Voltage: 80 ~ 264 VAC at 50/60 HZ
  • Typical Power Consumption: < 25W
  • Intel Pentium II 350 MHz-compatible or Mac G3 processor & greater
  • Microsoft Windows XP/Vista/7 or Mac OS 8.6 & greater
  • USB 2.0 equipped system
  • For USB 2.0 speeds, the system must support USB 2.0 specifications
Operating Environment
  • Operating: 0-35° C (95°F)
  • Non-operating: 0-1550°F, ½ hr per ASTM E119
  • Operating Humidity: 20% - 80% (non-condensing)
  • Non-operating Humidity: 100%, Full water immersion, 10 feet, 3 days.
Physical
  • Size: 5.0"W x 7.1"H x 11.0"L
  • Weight: 15 lbs
Data Recovery Service (DRS) and No-Hassle™ Warranty
  • 1 Year Data Recovery Service (DRS) included - one time, any reason, no questions asked
  • 3 Year No-Hassle™ Warranty included - replacement or repair for any defects or damage
  • DRS includes accidental deletion, any damage, disasters or hardware failure
  • Up to $1,000 included for third party forensic recovery service if needed for DRS
  • 3 and 5 year upgrades for DRS and No-Hassle™ Warranty plans available at www.iosafe.com
  • Fireproof
    DataCast endothermic fire insulation technology protects your data from extreme heat. The DataCast formulation forms a chemical bond with water molecules that, at temperatures above 160°F, releases water vapor to limit the internal temperature of the unit during a fire.
  • Active airflow cooling
    FloSafe active airflow cooling technology provides cooling airflow through the enclosure and across the disk drives during normal operating conditions. If destructive heat levels are sensed, such as in a fire, the FloSafe vents limit and protect your data from the extreme heat.
  • Waterproof
    HydroSafe water barrier technology is designed to protect data loss from fresh or salt water damage, including full immersion. While keeping your data dry, the HydroSafe technology still allows heat to dissipate during normal operation.
  • Theftproof
    The built in anti-theft tab allows you to easily secure the ioSafe Solo to any surface and keeps your data protected in the event of a break in. Securing the drive also prevents the drive from moving during a disaster.
  • Protect your memories
    With the ioSafe Solo fireproof waterproof external hard drive you can rest knowing that your priceless memories - your family photos and home videos - are safe no matter the circumstance. Spend your time making memories, not worrying about how to protect them.
  • PC and laptop backup
    Want to protect your entire digital life - your photos, videos, media, emails, and documents - in one fell swoop? The ioSafe Solo is the simple and safe way to instantly protect your entire PC or laptop. Never again worry about losing your data when your computer or hard drive crashes. When you backup your data to an ioSafe Solo restoring your computer after a disaster is fast and painless.
  • Simple Plug and Play
    With it's simple USB 2.0 interface getting the ioSafe Solo up and running is as simple as plugging it in. Plus USB 2.0 gives you the ability to use your Solo with almost any Mac or PC.
  • In-home media vault
    With the ioSafe Solo your extensive music and movie libraries are protected against almost anything. Never again will you have to worry about losing your favorite albums, playlists, or movies. With your media protected, you'll get to spend your time enjoying your media collections - and never risk wasting time and money restoring them.
ioSafe Solo - hard drive - 2 TB - USB 2.0
Hard drive - external (desktop)
2 TB
USB 2.0
Data Transfer Rate
480 Mbps
Spindle Speed
7200 rpm
Security lock slot (cable lock sold separately), water resistant, fire resistant, FloSafe
Power Source
Included AC adapter
12.7 cm x 27.9 cm x 18 cm
6.8 kg
Europe
3-year warranty
Bundled with
1 year Data Recovery Service
2 TB
USB 2.0
12.7 cm
27.9 cm
18 cm
6.8 kg
Bundled with
Performance
Interface Transfer Rate
480 Mbps
Spindle Speed
7200 rpm
Expansion & Connectivity
1 x USB 2.0 - 4 pin USB Type B
Power Source
Included AC adapter
Power adapter
Power Consumption
25 Watt (active)
Apple MacOS 8.6 or later, Microsoft Windows Vista / XP / 7
System Requirements Details
Windows XP/Vista/7 - Pentium II - 350 MHz , MacOS 8.6 or later - PowerPC G3
1 x USB cable - external
Plug and Play, UL, FCC
Europe
Limited warranty - 3 years
35 °C
20 - 80%
