Iomega PCI Express Adapter USB 3.0
Quicklinx: 71HRWS00 Mfr#: 34948
Iomega offers USB 3.0 adapter cards to insert in your desktop computer so you can experience native USB 3.0 transfer speeds up to 5 Gbits/s! This card is also backwards compatible with USB 2.0 devices. Connections to USB 2.0 devices will lead to USB 2.0 performance.
  • Enhanced compatibility
    Designed to seamlessly integrate with PC systems, this USB adapter ensures a smooth connection interface for a wide range of applications.
  • High-speed connectivity
    Featuring USB 3.0 ports, the adapter offers rapid data transfer rates, making it ideal for efficient file transfers.
  • Easy installation
    With its plug-in card form factor and PCI Express interface, the adapter is designed for quick and straightforward installation, requiring minimal setup effort.
Iomega - USB adapter - PCIe - USB 3.0 x 2
USB adapter
Plug-in card
Interface (Bus) Type
PCI Express
Ports
USB 3.0 x 2
USB 3.0
USB 1.1, USB 2.0, USB 3.0
Microsoft Windows Vista / XP / 7
1-year warranty
P/N: 34985, 35054
USB adapter
Plug-in card
PCI Express
Ports
USB 3.0 x 2
Wired
SuperSpeed USB 3.0
2 x USB 3.0
Compatible Slots
1 x PCI Express
Software Included
Drivers & Utilities
Limited warranty - 1 year
P/N: 34985, 35054
