Speed up the customer checkout experience with the SG20 handheld scanner, available with the industry's fastest 2D bar code imaging technology for quick, flawless scans - every time. Ergonomically designed for the needs of countertop scanning applications in retail, office, library, and light manufacturing.
The Intermec SG20 is an affordable, high-performance handheld scanner available in a range of models suited to the demands of general purpose countertop scanning.
Perfectly matched to your needs
Select between Bluetooth wireless for up to 10 meters of range, or the simplicity of tethered (cabled) connectivity. Now you can standardize on a single scanner family across your operation, while providing employees with just the right capabilities they need for their specific tasks. -
Setting a new design standard
The stylish design of the SG20 sets it apart from traditional gun-shaped handheld scanners. Careful attention to detail and extensive usability testing have resulted in a scanner that is not only aesthetically pleasing on any countertop, but also optimized for user comfort, with a natural smooth grip and trigger location. The arching profile of the SG20 is perfect for tight spaces and the over-sized multi-color LED provides a bright, visual cue to confirm a successful scan, which can be helpful in noisy environments. In fact, the LED can be programmed to match the decor of your storefront. -
Part of a complete Intermec solution
The SG20 can be quickly and easily configured with Intermec's exclusive EasySet PC programming tool. In just a few clicks, this Windows-based utility can print programming bar codes for custom configurations. Adjust security settings, symbologies, beeper tone and volume, LED color - even set up advanced data-editing routines.
 - Intermec SG20B General Duty Imager - barcode scanner
 - Barcode scanner - handheld - Bluetooth 2.1 EDR - decoded
 - Black
- Minimum Bar Width
 - 6 mil
- Scan Element Type
 - Linear imager
- Connectivity Technology
 - Wireless
- Wireless Connectivity
 - Bluetooth 2.1 EDR
- Battery
 - Lithium Ion
 - 6.1 cm x 20 cm x 6.5 cm
 - 175 g
 - 3-year warranty
 - Black
Barcode
- Interface Type
 - Bluetooth 2.1 EDR
- Minimum Bar Width
 - 6 mil
- Scan Element Type
 - Linear imager
- Scan Mode
 - Single-pass
- Max Working Distance
 - 50 cm
- Decode Capability
 - Code 93, Matrix 2 of 5, Code 39, GS1 DataBar, Telepen, Codabar, Code 128, Code 11, UPC, Interleaved 2 of 5, MSI-Plessey, Code 93i, GS1 DataBar Omnidirectional, GS1 DataBar Expanded, GS1 DataBar Limited, Standard 2 of 5, GS1 DataBar Composites
- TTL Decoding
 - Decoded
 - Wireless
 - Bluetooth 2.1 EDR
 - 1 x USB - Type A
- Included Accessories
 - Cradle
- Cables Included
 - 1 x USB cable - 1.83 m
 - UL, C-Tick, CISPR 22 Class B, EN55022, NOM, ICES-003 Class B, FCC Part 15 B, RoHS, WEEE, ANATEL, IEC 60529 IP30, REACH, CQC
- Power Device
 - Power adapter - external
- Battery
 - Lithium Ion
 - 6.1 cm
 - 20 cm
 - 6.5 cm
 - 175 g
 - Limited warranty - 3 years
 - 0 °C
 - 50 °C
 - 5 - 95% (non-condensing)
- Drop Specification
 - 1.2 m to concrete
