Add the InFocus LiteShow III wireless presentation adapter to any projector or other display to quickly and easily share data, audio, and video over a secure wireless connection.
Fast and convenient wireless connection
LiteShow III displays seamless video and allows for easy connection and display from long range. -
Tools for collaboration
The powerful Moderator feature allows a room full of computers to connect to a display and gives a "moderator" (via a web page) the ability to select which screen is displayed. -
Flexible and secure
LiteShow III is flexible enough to be used for wireless display only or configured to fit into the most complex and secure network infrastructure. LiteShow III maintains your security standards while giving multiple options for network and Internet access. It complies with the security protocols.
- InFocus LiteShow III - presentation server - Wi-Fi
- Presentation server
- Form Factor
- External
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Included Accessories
- 802.11n network adapter (USB 2.0)
- OS Required
- Microsoft Windows XP, Apple MacOS X 10.4 or later, Microsoft Windows Vista, Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits)
- 13.375 cm x 13.97 cm x 3.175 cm
- 230 g
- 1-year warranty
- Designed For
- InFocus IN102, IN104, IN105, IN2112, IN2114, IN2116, IN3114, IN3116, IN3914, IN3916, IN5110, IN5122, IN5124, IN5302, IN5304, IN5502, IN5532, IN5533, IN5533L, IN5535, IN5535L, INF4201, INF5501, INF6501; Learn Big IN5102; Work Big IN5108
- 13.375 cm
- 13.97 cm
- 3.175 cm
- 230 g
- Form Factor
- External
- Connectivity Technology
- Wireless, wired
- Data Transfer Rate
- 150 Mbps
- Max Range Open Space
- 91 m
- MIMO technology
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA, WPA2-PSK, WPA-Enterprise
- IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Aerial
- Antenna
- External detachable
- Antenna Qty
- 2
- 1 x VGA - HD-15 , 1 x audio line-in - mini-jack , 1 x 100Base-TX - RJ-45 , 1 x audio line-out - mini-jack
- C-Tick, NOM, FCC
- Power Device
- External power adapter
- OS Required
- Limited warranty - 1 year
- Designed For
- InFocus IN102, IN104, IN105, IN2112, IN2114, IN2116, IN3114, IN3116, IN3914, IN3916, IN5110, IN5122, IN5124, IN5302, IN5304, IN5502, IN5532, IN5533, IN5533L, IN5535, IN5535L, INF4201, INF5501, INF6501 , InFocus Learn Big IN5102 , InFocus Work Big IN5108
