The InFocus IN120STa Series projectors combine short throw, high brightness, networking and low cost - making them perfect for classrooms, offices, or tight spaces like trade show booths. These value-packed projectors are easy to buy and built to perform with multiple ways to connect, beautiful image quality, and option to convert to an interactive projector. Plus, the short throw lens reduces shadows, prevents light from shining in the presenter's face, and saves space.
High brightness and high contrast
The image quality of these projectors will not disappoint. 3300 lumens will give you bright, clear images with the lights on and the high 15000:1 contrast ratio adds sharpness with darker blacks and whiter whites. The short throw lens gives you big images in tight spaces and prevents light from shining in the presenter's face. -
Make it interactive
Plug in the optional LiteBoard adapter to turn your wall into an engaging, collaborative interactive workspace. Control all your favorite PC or Mac applications from around in the room with the wireless LiteBoard Wand just as you would with your mouse. -
Easy display from any device
Built-in apps and optional wireless adapter displays files from an Apple or Android notebook, tablet or smartphone. Or display from no device at all and project images, audio and video from the projector's on-board 2GB of memory. -
Networking and room control
Connect the projector to your network and manage it remotely. Send important announcements or emergency notifications for instant display, set up notifications for low lamp life, schedule when it gets powered down, and more. Crestron RoomView Connected and AMX Device Discovery technology is built into the projectors for easy connectivity, programming and control with those room control systems.
- InFocus IN126STA - DLP projector - short-throw - 3D
- DLP projector - 720p
- 3D Capable
- Yes (3D glasses sold separately)
- Built-in Devices
- Speaker
- Brightness
- 3300 lumens
- Contrast Ratio
- 15000:1
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Colour Support
- 1.07 billion colours
- Lens
- Short-throw fixed lens
- Bulb type
- UHP 240 Watt
- Bulb life cycle
- Up to 3500 hour(s) - normal mode , Up to 7000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video (NTSC, SECAM, PAL) - MPEG-1, MPEG-4, MJPEG, WMV, XviD, H.264, H.263
- Storage Capacity
- 2 GB Flash
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- 29.2 cm x 22 cm x 10.8 cm
- 3.2 kg
- 1-year warranty
- 3D Capable
- Built-in Devices
- Speaker
Projector
- Brightness
- 3300 lumens
- Brightness (Reduced)
- 3000 lumens
- Contrast Ratio
- 15000:1
- Throw Ratio
- 0.48:1
- Resolution
- WXGA - WXGA (1280 x 800) (native) / 1920 x 1200 (resized)
- 16:10
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 91 kHz
- Bulb type
- UHP 240 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- OSD Languages
- Danish, Hungarian, Czech, Indonesian, Chinese (traditional), Chinese (simplified), Vietnamese, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Romanian, Korean, Persian
- Eco-Mode technology, 6-segment colour wheel, JPEG photo playback, MP3 playback, DLP 3D Ready, 16:9 aspect ratio support, BMP photo playback, 16:10 aspect ratio support, DOC files support, PPT files support, XLS files support, PDF files support, 4:3 aspect ratio support, upgradable firmware, WAV playback, OGG playback, DOCX files support, PPTX files support, XLSX files support, WMA playback, AAC playback, MP1 playback
Lens
- Focus Type
- Manual
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- NTSC, SECAM, PAL
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
- Video Modes
- Digital Video Format
Media Player
- Storage Capacity
- 2 GB Flash
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 2 Watt
- Speakers
- 1 x mixed channel
- 1 x composite video input - RCA , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x S-video input - 4 pin mini-DIN , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB - 4 pin mini-USB Type B , 2 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x HDMI - 19 pin HDMI Type A , 1 x USB - 4 pin USB Type A , 1 x USB - 4 pin USB Type B , 1 x network - RJ-45
- Included Accessories
- Remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Security lock slot (cable lock sold separately), PIN code, security bar
- UL, cUL, FCC
- 29.2 cm
- 22 cm
- 10.8 cm
- 3.2 kg
- Limited warranty - 1 year , Limited warranty - lamp - 6 months , Limited warranty - accessories - 90 days
- 0 °C
- 40 °C
- Sound Emission
- 32 dB
- Sound Emission (Economic Mode)
- 30 dB
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
