iiyama Prolite XUB2493HS-B5 24" IPS LCD
Quicklinx: H40YWS00 Mfr#: XUB2493HS-B5
Stylish edge-to-edge design makes the ProLite XUB2493HS perfect for multi-monitor set-ups. The IPS panel technology offers accurate and consistent color reproduction with wide viewing angles. High-contrast and brightness values mean the monitor will provide excellent performance for photographic and web design. Equipped with speakers, headphone socket, HDMI and DisplayPort connections, a blue light reducer function to reduce eye fatigue and an ergonomic 150mm height adjustable stand for optimal user comfort, make this 24'' monitor a great choice for both multi-monitor configuration and office applications.
  • IPS technology
    IPS displays are best known for wide viewing angles and natural, highly accurate colors. They are especially suited for color-critical applications.
  • Eye-saving functions
    The ultimate solution for the comfort and health of your eyes. Flicker-free monitors with the blue light reducer function substantially reduce the strain and fatigue caused by flickering and blue light emittance of regular monitors.
  • High-quality speakers
    Playing with friends? Use the integrated high-quality speakers. Don't want to disturb anybody? Plug your headset into the headphone socket and turn the volume up.
  • Advanced contrast ratio
    Contrast ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced contrast ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games.
iiyama ProLite XUB2493HS-B5 - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class D
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Pixel Pitch
0.275 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 80000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Screen Coating
Matte
Voltage
AC 100-240 V (50/60 Hz)
Matte black
53.95 cm x 20.95 cm x 34.3 cm
5.7 kg
Environmental Standards
TCO Certified Displays 9
DDC-2B, DDC/CI, RoHS, WEEE, PSE Mark, REACH, TUV Bauart, ERP, VCCI Class B, EAC, UKCA
3-year warranty
Display Type
Energy Class
Class D
Diagonal Size
24"
Viewable Size
23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.275 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms (grey-to-grey)
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Matte
Backlight Technology
LED backlight
OSD Languages
Czech, English, German, French, Italian, Polish, Russian, Dutch, Japanese
HDCP, Eco-Mode, Overdrive technology, Advanced Contrast Ratio (ACR), X-Res Technology, Flicker Free technology, i-Style Color, Adaptive-Sync technology, 3 Side Borderless Design, Blue Light Reducer Function
Matte black
5.7 kg
Audio
Speakers - stereo
Output Power / Channel
2 watt
HDMI , DisplayPort , Headphones
Mechanical
Tilt Angle
-5/+23
Swivel Angle
90
Rotation Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management, VESA interface support
1 x HDMI cable , 1 x power cable
Security Slot Type
Kensington security slot
Input Voltage
14 kWh/1000h
Power Consumption (Typical)
15 watt
Power Consumption Stand by
0.3 watt
Power Consumption (Off Mode)
0.3 watt
Apple MacOS X
Shipping Width
63.5 cm
Shipping Depth
14.5 cm
Shipping Height
39 cm
Shipping Weight
6.4 kg
Sustainability Information
TCO Certified
Limited warranty - 3 years - on-site
