The T2252MTS lets you browse the web, email and draw while working on multiple screens, docking or typing on the on-screen keyboard. You can scroll and rotate pictures, draw, zoom in and out using certain tap, flick, grab and pincer gestures. The multi touch is not only fast but also fun to work with. Multiple inputs (VGA/ HDMI/ DVI) are available for flexible connectivity along with USB for the touch Interface.
VESA mount
VESA mount compliance means you can easily mount the LFD to any mounting that complies with the VESA standard. -
Touch technology - optical
This technology uses cameras. A touch event is registered with great accuracy when light is blocked by a finger or stylus. It's the only touch technology that does not rely on an overlay or substrate to register a touch, so it's impossible to physically "wear out" the touchscreen. In fact you don't really have to physically touch the screen. -
OverDrive feature
When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that. -
Speakers
This LED monitor is equipped with two high quality stereo speakers. -
Advanced Contrast Ratio
Contrast Ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games.
- iiyama ProLite T2252MTS-b5 - LED monitor - Full HD (1080p) - 22"
- LED-backlit LCD monitor - 22" - touchscreen
- Energy Class
- Class A
- Energy Consumption per Year
- 30 kWh
- Power Consumption (On mode)
- 20.2 W
- Touch-screen, stylus
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 12000000:1 (dynamic)
- Response Time
- 2 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI-D, VGA
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 51.65 cm x 22.05 cm x 37.15 cm
- 5.7 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, DDC-2B, VESA DPMS, TUV Bauart
- Display Type
- Energy Class
- Class A
- 30 kWh
- Diagonal Size
- 22"
- Viewable Size
- 21.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Brightness w/touchscreen
- 220 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 2 ms
- Vertical Refresh Rate
- 55 - 75 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Horizontal Viewing Angle
- +85 / -85
- Vertical Viewing Angle
- +80 / -80
- Backlight Technology
- LED backlight
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Polish, Russian, Dutch, Japanese
- HDCP, Eco-Mode, Overdrive technology, Advanced Contrast Ratio (ACR), i-Style Color
- Black
- 5.7 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 1 watt
Input
- Touch-screen, stylus - touchscreen
- Movement Detection Technology
- Optical
- VGA , DVI-D , HDMI (HDCP) , Headphones , USB , Audio line-in
Mechanical
- Tilt
- Tilt Angle
- -3/+73
- VESA Mounting Interface
- 100 x 100 mm
- Included Accessories
- Stand
- Cables Included
- 1 x VGA cable - VGA to VGA , 1 x DVI cable - DVI-D to DVI-D , 1 x audio cable , 1 x USB cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- 20.2 W
- Power Consumption (Typical)
- 15 watt
- Power Consumption Stand by
- 0.5 watt
- Included Software
- Driver
Sustainability Information
- ENERGY STAR Certified
- 5 °C
- 35 °C
- 10 - 80% (non-condensing)
StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount | In Stock | £139.14 |
StarTech.com Articulating Monitor Arm | In Stock | £121.96 |
StarTech.com Dual Monitor Stand | In Stock | £82.12 |
StarTech.com TV/Monitor Arm - Wallmount | In Stock | £85.61 |
