With its Full HD (1920x1080) resolution and accurate Projective Capacitive 10 point touch technology, the ProLite T2236MSC delivers seamless and accurate touch response. The AMVA panel technology guarantees high performance with excellent color reproduction and high contrast, making it an excellent choice for a vast array of demanding interactive applications. The flexible stand can be positioned at several angles creating a comfortable and ergonomic user experience. The ProLite T2236MSC is the ideal screen for a great touch-experience.
Touch technology - capacitive
This technology uses a sensor-grid of micro-fine wires integrated into the glass that covers the screen. Touch is detected because electrical characteristics of the sensor grid change when human finger is placed on the glass. Thanks to the glass overlay this technology is highly durable, and the touch function remains unaffected even if the glass is scratched. -
AMVA
AMVA technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it. -
Scratch resistance
Scratch resistance is essential for touch solutions used in public places and schools. This is achieved thanks to a glass overlay covering the screen. It guarantees high durability of the touch function and even more importantly the touch function remains unaffected even if the glass is scratched. -
Blue light reducer
Looking at a monitor screen for several hours per day, especially form a closer distance, causes eye fatigue. This effect is much stronger with computer screens than with TV equipment. One of the factors responsible for this phenomenon is the blue light emitted by the screen. Therefore reducing the amount of blue light ultimately allows the eyes to feel less tired while working long hours. -
Speakers
This LED monitor is equipped with two high quality stereo speakers.
- iiyama ProLite T2236MSC-B2 - LED monitor - Full HD (1080p) - 22"
- LED-backlit LCD monitor - 22" - touchscreen
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/362497
- Energy Class
- Class F
- Energy Consumption per Year
- 34 kWh
- Power Consumption (On mode)
- 18.5 W
- Touch-screen, USB 3.0 hub
- Panel Type
- A-MVA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3000:1 / 12000000:1 (dynamic)
- Response Time
- 8 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI-D, VGA
- Tilt
- Screen Coating
- 7H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 52.25 cm x 25.4 cm x 36.7 cm
- 5.8 kg
- DDC-2B, VESA DPMS, TUV Bauart
- 3-year warranty
- Display Type
- Energy Class
- Class F
- 34 kWh
- Diagonal Size
- 22"
- Viewable Size
- 21.5"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- A-MVA
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Brightness w/touchscreen
- 213 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Horizontal Viewing Angle
- +89 / -89
- Vertical Viewing Angle
- +89 / -89
- Screen Coating
- 7H Hard Coating
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Volume, brightness, contrast, H/V position, input select, colour temperature, phase, aspect control, blue reduction
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish, Japanese
- Eco-Mode, Advanced Contrast Ratio (ACR), 10-point multi-touch, blue light reduction
- Black
- 52.25 cm x 25.4 cm x 36.7 cm - with stand
- 5.8 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
Input
- Touch-screen - touchscreen
- Movement Detection Technology
- Projected capacitive
- VGA , DVI-D , HDMI , Headphones , USB 3.0 upstream (Type B) , 4 x USB 3.0 downstream (Type A)
Mechanical
- Tilt
- Tilt Angle
- -5/+90
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable - VGA to VGA , 1 x DVI cable - DVI-D to DVI-D , 1 x audio cable , 1 x SuperSpeed USB cable - USB Type A to B
- Security Slot Type
- Kensington security slot
- Input Voltage
- 18.5 W
- Power Consumption SDR (On mode)
- 18.5 kWh/1000h
- Power Consumption (Typical)
- 23 Watt
- Power Consumption Stand by
- 0.5 Watt
- On / Off Switch
- No
- Included Software
- Driver
- OS Required
- Microsoft Windows 7 / Windows 8
- Dimensions & Weight Details
- With stand - width: 52.25 cm - depth: 25.4 cm - height: 36.7 cm - weight: 5.8 kg , Without stand - width: 52.25 cm - depth: 5.7 cm - height: 31.6 cm
- Limited warranty - 3 years
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
