iiyama Prolite T1634MC-B4X 16" 5ms VGA DVI-D USB Touch Display
Quicklinx: CB0FWS00 Mfr#: T1634MC-B4X
The 15.6" LED-backlit ProLite monitor uses Projective Capacitive Multi-Touch technology, built into an eye catching bezel with edge-to-edge glass. The screen features DVI and VGA inputs and a rugged bezel front making it suitable for demanding environments. The ProLite monitor is the ideal solution for in-store retail and kiosk integration.
  • Touch technology
    This technology uses a sensor-grid of micro-fine wires integrated into the glass that covers the screen. Touch is detected because electrical characteristics of the sensor grid change when human finger is placed on the glass. Thanks to the glass overlay this technology is highly durable, and the touch function remains unaffected even if the glass is scratched. It offers perfect picture performance and will work with human finger (gloved or not) and magnetic ball.
  • Scratch resistance
    Scratch resistance is essential for touch solutions used in public places and schools. This is achieved thanks to a glass overlay covering the screen. It guarantees high durability of the touch function and even more importantly the touch function remains unaffected even if the glass is scratched.
  • LED backlit
    A typical CCFL LCD uses four backlight lamps. Using LED diodes considerably lowers the power consumption and reduces the CO2 emission into the environment making this LCD a true eco-friendly product.
iiyama ProLite T1634MC-B4X - LED monitor - 15.6"
LED-backlit LCD monitor - 15.6" - touchscreen
Touch-screen
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1366 x 768
Pixel Pitch
0.252 mm
Brightness
400 cd/m²
Contrast Ratio
500:1
Response Time
8 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Screen Coating
7H Hard Coating
Voltage
DC 12 V
38.1 cm x 20.2 cm x 28.55 cm
4.4 kg
VCCI, DDC-2B, VESA DPMS, IP54, TUV Bauart
Display Type
Diagonal Size
15.6"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1366 x 768
Pixel Pitch
0.252 mm
Brightness
400 cd/m²
Brightness w/touchscreen
360 cd/m²
Contrast Ratio
500:1
Colour Support
Response Time
8 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
31.4 - 60.3 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Screen Coating
7H Hard Coating
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, H/V position, input select, colour temperature, phase, H-size
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Spanish, Japanese
Edge-to-edge glass, HID Compliant, scratch-resistant, Projected Capacitive Touch (P-CAP) technology
38.1 cm x 20.2 cm x 28.55 cm - with stand
4.4 kg
Input
Touch-screen - touchscreen
Movement Detection Technology
Projected capacitive
VGA , DVI-D , USB (Type B)
Mechanical
Tilt
Tilt Angle
-5/+90
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x DVI cable , 1 x USB cable
Input Voltage
DC 12 V
Power Consumption (Typical)
16 watt
Included Software
Drivers & Utilities
Microsoft Windows NT 4.0, Microsoft Windows 95/98, Microsoft Windows CE, Linux, Microsoft Windows 2000, Apple MacOS X, Microsoft Windows XP, Microsoft Windows Vista, Microsoft Windows 7 / 8 / 10
Dimensions & Weight Details
Without stand - width: 38.1 cm - depth: 5.3 cm - height: 23.05 cm , With stand - width: 38.1 cm - depth: 20.2 cm - height: 28.55 cm - weight: 4.4 kg
