iiyama ProLite E2283HS 21.5" 1920x1080 2ms VGA DVI-D HDMI LED Monitor
Quicklinx: 9MVGWS00 Mfr#: E2283HS-B1
The ProLite E2283HS is an excellent 22" Full HD LED-backlit monitor with 1920 x 1080p resolution. It features 2ms response time and more than 5000000:1 Advanced Contrast Ratio, assuring clear and vibrant picture quality and high contrast. Triple input support ensures compatibility with the latest installed graphics cards and embedded notebook outputs. The E2283HS is also equipped with two high quality stereo speakers.
  • ACR
    Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games.
  • Full HD
    With true 1920 x 1080p resolution your monitor is ready to display high definition images. This means you can accommodate more information on your screen; e.g. 60% more in comparison to a 1280 x 1024 monitor.
  • LED-backlit
    A typical CCFL LCD uses four backlight lamps. Using LED diodes considerably lowers the power consumption and reduces the CO2 emission into the environment making this LCD a true ECO-friendly product.
  • Overdrive on/off
    When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that.
  • HDMI
    HDMI stands for High-Definition Multimedia Interface. Much smaller and more convenient than DVI, HDMI also has the significant advantage over DVI that it supports audio as well as video signals.
  • Speakers
    This LED monitor is equipped with two high quality stereo speakers.
iiyama ProLite E2283HS - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Class
Class B
Energy Consumption per Year
32 kWh
Power Consumption (On mode)
21.8 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
1 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Voltage
50.55 cm x 19.3 cm x 38.25 cm
3 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, DDC-2B, VESA DPMS, VCCI Class B
Display Type
Energy Class
Class B
32 kWh
Diagonal Size
21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Backlight Technology
LED backlight
Controls & Adjustments
Mute, volume, brightness, contrast, H/V position, sharpness, input select, colour temperature, phase, clock
OSD Languages
Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese, Chinese
HDCP, Eco-Mode, Overdrive technology, Advanced Contrast Ratio (ACR)
3 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 watt
VGA , DVI-D , HDMI , Headphones , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+22
VESA Mounting Interface
100 x 100 mm
1 x DVI cable - DVI-D to DVI-D , 1 x audio cable
Power Supply
Internal
Input Voltage
21.8 W
Power Consumption (Typical)
21 watt
Power Consumption Stand by
0.5 watt
Included Software
Driver
Apple MacOS, Microsoft Windows 7, Microsoft Windows 95/98/ME/2000/XP/Vista, Windows 8
Sustainability Information
ENERGY STAR Certified
