iiyama ProLite B2791HSU-B1 27" 1920x1080 1ms VGA HDMI DisplayPort LED Monitor
Quicklinx: FJ0VWS00 Mfr#: B2791HSU-B1
Looking at a screen for long hours can be quite tiring for the eyes. But it doesn't have to. The Iiyama ProLite B2791HSU is big enough to make sure you can clearly see every detail and it comes equipped with technologies to help keep your vision intact. The panel backlight is flicker free and the blue light reducer function limits the amount of blue, the unfavorable, light emitted by the screen. The height adjustable stand allows you to easily adjust the screen position to make sure you are looking at it at the right angle.
  • Flicker free + blue light
    The ultimate solution for the comfort and health of your eyes. Flicker free monitors with blue light reducer function. Absolutely no flickering. And the amount of blue light emitted by the screen and responsible for your eyes feeling fatigued substantially reduced.
  • Has + pivot
    With a height adjustable stand you will create an ergonomic work posture and position that meets all health and safety requirements. This will not only prevent any health issues but will also increase your productivity. The pivot function allows the screen to rotate from landscape to portrait orientation. This functionality can be useful if the application requires more height than width.
  • FreeSync technology
    AMD FreeSync technology puts an end to choppy gameplay and broken frames with fluid, artifact-free performance at virtually any framerate.
iiyama ProLite B2791HSU-B1 - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class E
Energy Consumption per Year
29 kWh
Power Consumption (On mode)
19.7 W
Adaptive-Sync Technology
AMD FreeSync
USB 2.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 (DisplayPort: 75 Hz, VGA: 60 Hz, HDMI: 75 Hz)
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
1 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Matte
Voltage
61.35 cm x 23 cm x 39.75 cm
6.9 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, DDC-2B, VESA DPMS, CU
3-year warranty
Display Type
Energy Class
Class E
29 kWh
Diagonal Size
27"
AMD FreeSync
Built-in Devices
USB 2.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms (grey-to-grey)
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Screen Coating
Matte
Backlight Technology
LED backlight
OSD Languages
English, German, French, Italian, Polish, Russian, Spanish, Japanese, Chinese
HDCP, Eco-Mode, Overdrive technology, Advanced Contrast Ratio (ACR), Flicker Free technology, blue light reduction, i-Style Color, Black Tuner
61.35 cm x 23 cm x 39.75 cm - with stand
6.9 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , DisplayPort , HDMI , Audio line-in , 2 x USB 2.0 downstream , USB 2.0 upstream , Headphones
Mechanical
Tilt Angle
-5/+22
Swivel Angle
90
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable , 1 x USB cable
Mounting Kit
Included
Input Voltage
19.7 W
19 kWh/1000h
Power Consumption (Typical)
19 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Drivers & Utilities
Apple MacOS, Microsoft Windows
Dimensions & Weight Details
Without stand - width: 61.35 cm - depth: 5.4 cm - height: 37.05 cm , With stand - width: 61.35 cm - depth: 23 cm - height: 39.75 cm - weight: 6.9 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
5 °C
35 °C
10 - 80% (non-condensing)
