Iiyama Pro Lite E2208HDS-B2 22" Widescreen 1920 x 1080 2ms DVI VGA LCD Monitor with Speakers
Quicklinx: 5L6KWS00 Mfr#: E2208HDS-B2
Highlights of the IIyama 22" E2208HDS-1 monitor
Screen: 22" (1920 x 1080)
Brightness: 250 cd/m2
Contrast Ratio: 10000:1 (DCR)
Response time: 2ms
Connectivity: DVI, D-Sub, VGA (HD-15)
iiyama ProLite E2208HDS-2 - LCD monitor - Full HD (1080p) - 22"
LCD monitor - 22"
Stereo speakers
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.248 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 10000:1 (dynamic)
Response Time
2 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Voltage
51.7 cm x 19.3 cm x 38.6 cm
4.2 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TUV, VCCI Class B ITE
3-year warranty
Display Type
LCD monitor / TFT active matrix
Diagonal Size
22"
Built-in Devices
Stereo speakers
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
2 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
83 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+85 / -75
Controls & Adjustments
Mute, volume, brightness, contrast, H/V position, sharpness
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Finnish, Spanish, Japanese
HDCP
4.2 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
VGA , Audio line-in , DVI-D
Mechanical
Tilt
Tilt Angle
25
Security lock slot (cable lock sold separately), wall mountable
Stand
1 x VGA cable , 1 x audio cable , 1 x DVI cable
Power Supply
Internal
Input Voltage
Power Consumption (Typical)
43 Watt
Power Consumption Stand by / Sleep
2 Watt
Apple MacOS, Microsoft Windows 95/98/ME/2000/XP, Microsoft Windows Vista
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
Resources
The following resources are available for the Iiyama Pro Lite E2208HDS-B2 22" Widescreen 1920 x 1080 2ms DVI VGA LCD Monitor with Speakers
