Iiyama Mini PC / Thin Client Bracket for Iiyama Stands
Quicklinx: 8XQMWS00 Mfr#: MD BRPCV01
MD BRPCV01 is a high quality bracket that allows a Mini PC or Thin Client to be mounted to the iiyama Height Adjustable stand. This solution is compatible with almost all ThinClient/ZeroClient PC's and with basically all iiyama 19'' to 24'' height adjustable monitors (B1980SD, B2080HSD, B2280HS/WSD, XB2380HS, B2480HS/HSU, B2481HS and XB2485WSU).
