Stylish dual desk mount stand
The iiyama DS1002D-B1 is a desk mount stand for two flat screens up to 30". The monitor arm allows you to save space on your desk reducing the number of stands to one only and the cable management system makes it easier to keep your workplace tidy. The easy to set-up stand offers broad adjustment capabilities, including tilt, swivel, height and rotation, so you can easily adjust the position of both screens to your preferences assuring comfortable and healthy body posture.
Practical Dual Screen solution
Using an iiyama Dual Desk Mounting arm, enables users to quickly adjust the orientation of their display set up. The monitor arm allows you to save desk space, reducing the number of stands to one only and the cable management system keeps your workplace tidy.
Enhanced Productivity
In todays demanding environment, using two or more screens makes a huge improvement to productivity, whether in the office or at home. Research has shown that being able to manipulate multiple applications at the same time improves speed on comparing and contrasting, reviewing work and analysing data from multiple sources.
Easy to install mounting solution
iiyama mounting solutions come with everything you need to install onto a desk in the box. They are very quick and simple to set up, and each mount is supplied with a cable management system to securely hide away power and data cables from view.
Flexible range of movement
Each arm can be moved independently, enabling users to adjust the height and orientation (portrait to landscape) or their screens to create a flexible work space.
Effortless adjustability
Featuring an adjustable arm with a 14 cm lift, 180° pan, and a 90° rotation capability, this stand offers flexibility. Users can easily adjust their dual-monitor setup to their preferred viewing angle, enhancing comfort and productivity throughout the day. -
Versatile compatibility
Designed to support a wide range of display sizes from 10" to 30" (25.4-76.2 cm) and equipped with both 100 x 100 mm and 75 x 75 mm flat panel mount interfaces, this stand is compatible with nearly any desktop monitor setup. -
Optimized workspace
With integrated cable management, this stand keeps cables neatly organized, resulting in a cleaner and more efficient workspace. The tilt range of -85° to 15° allows for further customization, ensuring optimal viewing angles and reduced glare.
- Iiyama DS1002D-B1 stand - adjustable arm - for 2 monitors - black
- Product Type
- Stand (adjustable arm) - desktop stand
- Tilt
- -85° to 15°
- Pan
- 180°
- Lift
- 14 cm
- Rotation
- 90°
- Recommended Use
- 2 monitors
- Recommended Display Size
- 10"-30"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Max Load Weight
- 10 kg
- Black
- 5-year warranty
- Designed For
- ProLite E2783QSU-B1, XU2495WSU-B1, XUB2495WSU-B1
- Black
AV Furniture
- Stand
- Design
- Adjustable arm
- Recommended Use
- 2 monitors
- Placing / Mounting
- Desktop stand
- Cable Management
- Integrated cable management
- 10"-30"
- Tilt
- -85° to 15°
- Pan
- 180°
- Lift
- 14 cm
- Rotation
- 90°
- Max Load Weight
- 10 kg
- Limited warranty - 5 years
- Designed For
- Iiyama ProLite E2783QSU-B1, XU2495WSU-B1, XUB2495WSU-B1
