RaidSonic's target is to develop innovative products, which enrich and perfect the use of mass storage in a functional, aesthetic and high quality way. By the consequent use of high class components and materials, RaidSonic has positioned its products in the upper level market segment.
- ICY BOX IB-250U-B - storage enclosure - ATA-133 - USB 2.0
- Storage enclosure - external
- Bus Type
- USB 2.0
- Black
- Expansion Bays
- 1 x internal - 2.5"
- Hard Drive Form Factor Compatibility
- 2.5"
- Interface
- ATA-133
- Data Transfer Rate
- 133 MBps
- Supported Devices
- Hard drive
- Max Storage Devices Qty
- 1
- Product Material
- Aluminium
- Power Source
- Additional USB, USB bus
- 7.7 cm x 13.5 cm x 1.2 cm
- 70 g
- 2.5"
- Host Bus
- USB 2.0
- Product Material
- Aluminium
- Black
Storage Controller
- Interface
- ATA-133
- 133 MBps
- Supported Devices
- Hard drive
- 1
- Bays
- 1 x ATA-133
- Connections
- 1 x USB 2.0 - 4 pin USB Type A
- Included Accessories
- Carrying case, USB (power) cable
- Cables Included
- 1 x USB cable - external
- Plug and Play
- Power Source
- Software Included
- Driver
- 7.7 cm
- 13.5 cm
- 1.2 cm
- 70 g
