The IBM System Storage DS3200 external storage enclosures are designed to be an easy, scalable, flexible, and affordable solution for System x and BladeCenter servers. The DS3200 is a 3Gb external SAS storage solution that is easy to deploy and manage. Available in single and dual controller models, the DS3200 scales in capacity to support a total of 48 hard disk drives by using the EXP3000 expansion unit. The DS3200 is a direct-attach solution for System x servers, and enables small and medium businesses manage their fast-growing data capacity requirements on an affordable budget.
- IBM System Storage DS3200 Model 22X - hard drive array
- Hard drive array
- Enclosure Type
- Rack-mountable - 2U
- Max Supported Capacity
- 12 TB
- Interface
- SAS
- Installed Devices / Modules Qty
- 0 (installed) / 12 (max)
- Supported Drives
- SAS
- Storage Controller
- RAID (SAS) - RAID 0, 1, 3, 5, 10
- Storage Controller Quantity
- 2
- Hard Drive
- 0 HDD - hot-swap
- Power
- AC 120/230 V - 50/60 Hz
- Power Redundancy
- Manufacturer Selling Program
- IBM Express Seller
- 48.2 cm x 52.1 cm x 8.7 cm
- 27.2 kg
- 3-year warranty
- Hard drive array
- Enclosure Type
Chassis
- 0
- Supported Devices / Modules Qty
- 12
- Supported Drives
- SAS
Storage
- 12 TB
- HDD Array External Interface
- SAS
Storage Controller
- RAID
- Installed Qty
- 2
- Interface Type
- SAS
- Cache / Buffer Size (Max)
- 512 MB
- Supported Devices
- Disk array (RAID)
- RAID Level
- RAID 0, RAID 1, RAID 3, RAID 5, RAID 10
Storage Controller (2nd)
- Installed Qty
- 2
Hard Drive
- HDD - hot-swap
- Capacity
- 0
- Expansion Bays
- 12 (total) / 12 (free) x hot-swap
- TUV, VCCI, C-Tick, cUL, NOM, CB, MIC, FCC, BSMI CNS 13438
- Power Device
- 2 x internal power supply - hot-plug
- Max Supported Qty
- 2
- Power Redundancy
- Power Redundancy Scheme
- 1+1
- Voltage Required
- 48.2 cm
- 52.1 cm
- 8.7 cm
- 27.2 kg
- Limited warranty - parts and labour - 3 years
- 10 °C
- 40 °C
- 20 - 80%
