Lenovo ServeRAID M5000 Series Battery Kit - Memory backup battery - 1 x Lithium Ion - for ServeRAID M5014; ServeRAID M5015; System x3250 M3; x3630 M3 7377; x3650 M3; x3950 X5
Enhanced compatibility
Designed specifically for PC systems, the Lenovo ServeRAID M5000 Series Battery Kit ensures seamless integration and optimal performance with compatible hardware. -
Reliable power
Equipped with lithium-ion technology, this battery kit provides a reliable power source for your Lenovo ServeRAID, ensuring your system remains operational and efficient.
- Lenovo ServeRAID M5000 Series Battery Kit - memory backup battery - Li-Ion
- 50 g
- Battery
- Lithium Ion
- Batteries Qty
- 1
- 5.4 cm x 1.6 cm x 8.3 cm
- Designed For
- ServeRAID M5014; ServeRAID M5015; System x3250 M3; x3630 M3 7377; x3650 M3; x3950 X5
- Quantity
- 1
- Technology
- Lithium Ion
- 5.4 cm
- 1.6 cm
- 8.3 cm
- 50 g
- Designed For
- IBM ServeRAID M5014 , Lenovo ServeRAID M5015 , Lenovo System x3250 M3 , Lenovo System x3630 M3 7377 , Lenovo System x3650 M3 , Lenovo System x3950 X5
