Improve printing performance of complex documents by enhancing data flow with HP memory upgrades.
- HP - DDR - module - 256 MB - SO-DIMM 200-pin - 333 MHz / PC2700 - unbuffered
- Product Type
- Memory module
- Capacity
- 256 MB
- Memory Type
- DDR SDRAM - SO-DIMM 200-pin
- Upgrade Type
- System specific
- Data Integrity Check
- Non-ECC
- Speed
- 333 MHz (PC2700)
- Unbuffered
- Designed For
- Color LaserJet CM6030 MFP, CM6030f MFP, CP6015de, CP6015dn, CP6015n, CP6015x, CP6015xh
- Capacity
- 256 MB
- Upgrade Type
- System specific
- DRAM memory module
- Technology
- DDR SDRAM
- Form Factor
- SO-DIMM 200-pin
- Speed
- 333 MHz (PC2700)
- Non-ECC
- Unbuffered
- Compatible Slots
- 1 x memory - SO-DIMM 200-pin
- Designed For
- HP Color LaserJet CM6030 MFP, CM6030f MFP, CP6015de, CP6015dn, CP6015n, CP6015x, CP6015xh
